Set Floor Coordinates
Humphery7
Post by Humphery7 »
Hello Coppelia,
Is it possible to set the coordinates of my floor, like specify where the (0,0) should be, cause by default it takes the center at (0,0), and I would like to specify the (0,0) to be at the left edge rather than the center, the reason I need this is so it can conform with the map I create with Dijkstra. If it is possible, please how do I go about doing that.
Re: Set Floor Coordinates
not sure I understand what you want to do. You can of course simply shift the floor, either manually, or set a new position via sim.setObjectPosition.
