Fail to set stepping mode for the remote API server service through"sim.simxSynchronous"
Hacher
Post by Hacher »
I'm trying to set the stepping mode for the remote API server service in external python script through the api function "simxSynchronous" so that I can control the simulation step by step.However it didn't work, and the return code of the simxSynchronous function is 8.I'm sure that right paramerters were input to the function and the communication between server and application was built correctly.
Looking forward your reply.
Re: Fail to set stepping mode for the remote API server service through"sim.simxSynchronous"
you are using the legacy remote API, which is deprecated since several years. Make sure to use the ZeroMQ remote API, which is much easier to use, more flexible, faster, and supports all regular API functions.
what version of CoppeliaSim are you using?
