Child Script Abort Execution
retnap
Post by retnap »
I'm trying to set Dijkstra and A* algorithm in same scene. I've added Quadcopter's target object threaded child script. When the simulation begins, codes can draw dijkstra and a* shortest paths. But when i press the follow buttons i got abort execuiton errors. How can i fix that ?
#python
import time
import heapq
import math
# Heuristik fonksiyon: Manhattan mesafesi
def heuristic(node, target_node):
    x1, y1 = node
    x2, y2 = target_node
    return abs(x1 - x2) + abs(y1 - y2)
# A* Algoritmas?
def a_star(graph, start_node, target_node):
    distances = {node: float('inf') for node in graph}
    previous_nodes = {node: None for node in graph}
    distances[start_node] = 0
    priority_queue = [(0, start_node)]
    while priority_queue:
        current_distance, current_node = heapq.heappop(priority_queue)
        if current_node == target_node:
            break
        for neighbor, weight in graph[current_node]:
            g_cost = current_distance + weight
            h_cost = heuristic(neighbor, target_node)
            f_cost = g_cost + h_cost
            if g_cost < distances[neighbor]:
                distances[neighbor] = g_cost
                previous_nodes[neighbor] = current_node
                heapq.heappush(priority_queue, (f_cost, neighbor))
    path = []
    current = target_node
    while current is not None:
        path.append(current)
        current = previous_nodes[current]
    path.reverse()
    return distances[target_node], path
def create_nodes(grid_size):
    nodes = []
    for i in range(grid_size + 1):
        for j in range(grid_size + 1):
            nodes.append((i, j))
    return nodes
def create_graph(nodes, grid_size, obstacles=[]):
    graph = {}
    for node in nodes:
        x, y = node
        neighbors = []
        if x > 0 and (x - 1, y) not in obstacles:
            neighbors.append(((x - 1, y), 1))
        if x < grid_size and (x + 1, y) not in obstacles:
            neighbors.append(((x + 1, y), 1))
        if y > 0 and (x, y - 1) not in obstacles:
            neighbors.append(((x, y - 1), 1))
        if y < grid_size and (x, y + 1) not in obstacles:
            neighbors.append(((x, y + 1), 1))
        graph[node] = neighbors
    return graph
# Dijkstra Algoritmas?
def dijkstra(graph, start_node, target_node):
            break
            distance = current_distance + weight
            if distance < distances[neighbor]:
                distances[neighbor] = distance
                heapq.heappush(priority_queue, (distance, neighbor))
    path = []
    path.reverse()
# A?a??daki fonksiyon, yolu sahnede ?izmek i?in kullan?lacak
def draw_path(path, color, thickness=5):
    drawing_object_handle = sim.addDrawingObject(sim.drawing_lines, thickness, 0, -1, 99999, color)
    for i in range(len(path) - 1):
        start_node = path[i]
        end_node = path[i + 1]
        start_pos = [start_node[0] * 0.5, start_node[1] * 0.5, 0.2]
        end_pos = [end_node[0] * 0.5, end_node[1] * 0.5, 0.2]
        sim.addDrawingObjectItem(drawing_object_handle, start_pos + end_pos)
# Quadcopter'in yolu takip etmesini sa?layan fonksiyon
def follow_path(path, quadcopter_handle):
    if not path or len(path) < 2:
        print("Hata: Yol gecersiz veya bos.")
        return
    if quadcopter_handle is None or quadcopter_handle < 0:
        print(f"Hata: Gecersiz quadcopter handle: {quadcopter_handle}")
        return
    steps_per_move = 100
    print(f"Quadcopter, yolu takip etmeye basliyor. Handle: {quadcopter_handle}")
    def move_along_path(path, steps_per_move):
            current_node = path[i]
            next_node = path[i + 1]
            current_x, current_y = current_node
            next_x, next_y = next_node
            current_pos = [current_x * 0.5, current_y * 0.5, 0.2]
            next_pos = [next_x * 0.5, next_y * 0.5, 0.2]
            print(f"Segment: {current_pos} -> {next_pos}")
            for step in range(steps_per_move):
                interpolated_x = current_pos[0] + (next_pos[0] - current_pos[0]) * (step / steps_per_move)
                interpolated_y = current_pos[1] + (next_pos[1] - current_pos[1]) * (step / steps_per_move)
                interpolated_z = current_pos[2]
                interpolated_pos = [interpolated_x, interpolated_y, interpolated_z]
                try:
                    sim.setObjectPosition(quadcopter_handle, -1, interpolated_pos)
                except Exception as e:
                    print(f"Pozisyon ayarlanirken hata: {e}")
                    return
                sim.wait(0.05)
                sim.switchThread()
    start_node = path[0]
    start_x, start_y = start_node
    start_pos = [start_x * 0.5, start_y * 0.5, 0.2]
    try:
        sim.setObjectPosition(quadcopter_handle, -1, start_pos)
        print(f"Quadcopter baslangic pozisyonuna yerlestirildi: {start_pos}")
        print(f"Baslangic pozisyonu ayarlanirken hata: {e}")
        return
    reverse_path = path[::-1]
    print("Yol tersine takip ediliyor...")
    move_along_path(reverse_path, steps_per_move)
    print("Yol basariyla tamamlandi.")
def sysCall_init():
    global dijkstra_path, astar_path
    sim = require('sim')
    simUI = require('simUI')
    # XML ile UI olu?turma
    xml = '''
    <ui title="Path Finding and Quadcopter Control" closeable="true" resizeable="false" activate="false">
        <group layout="vbox">
            <group layout="hbox">
                <button text="Dijkstra Path" on-click="onDijkstraPathClick" id="1"/>
                <button text="A* Path" on-click="onAStarPathClick" id="2"/>
            </group>
                <button text="Follow Dijkstra Path" on-click="onFollowDijkstraPathClick" id="3"/>
                <button text="Follow A* Path" on-click="onFollowAStarPathClick" id="4"/>
            </group>
        </group>
    </ui>
    simUI.create(xml)
def sysCall_thread():
    # A* ve Dijkstra hesaplamalar?n? burada ba?lat?yoruz
    grid_size = 10
    nodes = create_nodes(grid_size)
    obstacles = [(5, 9), (3, 9), (1, 5), (7, 5), (4, 2), (8, 2), (4, 7), (0, 0), (0, 6), (2, 3)]
    graph = create_graph(nodes, grid_size, obstacles)
    start_node = (9, 9)
    target_node = (1, 3)
    # A* ve Dijkstra algoritmalar?n? burada ?a??r?yoruz
    _, dijkstra_path = dijkstra(graph, start_node, target_node)
    _, astar_path = a_star(graph, start_node, target_node)
    print("A* Path:", astar_path)
    print("Dijkstra Path:", dijkstra_path)
    # ??lem tamamland?ktan sonra beklemek i?in
    sim.wait(0.5)  # Sim?lasyonun ilerleyi?ini durdurmamak i?in
    pass
def onDijkstraPathClick(ui, data):
    draw_path(dijkstra_path, color=[0, 1, 0])  # Ye?il renk
    print("Dijkstra yolu cizildi.")
def onAStarPathClick(ui, data):
    global astar_path
    draw_path(astar_path, color=[1, 0, 0])  # K?rm?z? renk
    print("A* yolu cizildi.")
def onFollowDijkstraPathClick(ui, data):
    quadcopter_handle = sim.getObject('/Quadcopter')
    print("Quadcopter Handle:", quadcopter_handle)
    follow_path(dijkstra_path, quadcopter_handle)
    print("Dijkstra yolu takip edildi.")
def onFollowAStarPathClick(ui, data):
    global astar_path
    follow_path(astar_path, quadcopter_handle)
    print("A* yolu takip edildi.")
Re: Child Script Abort Execution
when I try your script, I just get the abort script message/button, but no error: that message/button appears when the simulation has been stuck for a certain amount of time in a script. So that means you have either an infinite loop in that script, or an operation that takes several seconds/minutes to execute.
retnap
Post by retnap »
coppelia wrote: 06 Jan 2025, 13:01 Hello,
First, thank you for your important message. I'm trying to do something according to your message. But I couldn't handle with this. Do you have any suggestions ? Is it possible to follow a drawing path ?
