Running healess python client
gregor_ws
Post by gregor_ws »
Hi. I would like to run CoppeliaSim's python client in headless mode. Everything works fine with the GUI mode, using the libcoppeliaSim.so library, however I run into the following message when trying to use the libcoppeliaSimHeadless.so library:
* Please run the GUI version of CoppeliaSim Edu, *
* until requested to register your EDU version.  *
* Once registered, you'll be able to run the     *
* headless version.                              *
* CoppeliaSim will now shut down.                *
> [CoppeliaSim:loadinfo]   CoppeliaSim ended.
What is the process to register my Edu version?
Thanks in advance.
Re: Running healess python client
so your CoppeliaSim Edu was successfully registered and does not display the registration dialog (pops open after 15-20 minutes) when running in GUI mode, e.g. also via Python:
python ./coppeliaSim.py
...but running one of following does not work?
python ./coppeliaSim.py -h
python ./coppeliaSim.py -H
gregor_ws
Post by gregor_ws »
Thanks for the reply. I was using CoppeliaSim with the Python client and the registration message didn't have the chance to appear. After using the main client for a while it does appear and I can successfully register.
FYI, with CoppeliaSim V4.9 rev2 (or rev4), the headless mode will not require a registration anymore.
