I have this old scene file (definitely >5 years old) of the uarm robot, which worked perfectly back then. But when I run it with the latest CoppeliaSim v4.9.0 rev 6, two of the robot joints seems to disengage / pulled apart from each other.
[youtube]https://youtu.be/28gMYZCY01o[/youtube]
Can you give me a guide on how do I go about debugging this? There are no error messages, only warnings on deprecated functions.
[sandboxScript:info] Simulation stopped.
[sandboxScript:info] Simulation started.
[mainScript:warning] module 'sim' was implicitly loaded.
[mainScript:warning] the script is running in compatibility mode. It is highly recommended to switch to the new calling method, e.g.:
with the old method: if sim_call_type==sim.syscb_init then ... end
with the new method: function sysCall_init() ... end
[/uarm/uarmGripper@simulationScript:warning] module 'sim' was implicitly loaded.
[/uarm/uarmGripper@simulationScript:warning] the script is running in compatibility mode. It is highly recommended to switch to the new calling method, e.g.:
[/uarm/uarm_base@simulationScript:warning] module 'sim' was implicitly loaded.
[/uarm/uarm_base@simulationScript:warning] the script is running in compatibility mode. It is highly recommended to switch to the new calling method, e.g.:
[/DefaultCamera@simulationScript:warning] module 'sim' was implicitly loaded.
[/DefaultCamera@simulationScript:warning] the script is running in compatibility mode. It is highly recommended to switch to the new calling method, e.g.:
[/DefaultLightA@simulationScript:warning] module 'sim' was implicitly loaded.
[/DefaultLightA@simulationScript:warning] the script is running in compatibility mode. It is highly recommended to switch to the new calling method, e.g.:
[/DefaultLightB@simulationScript:warning] module 'sim' was implicitly loaded.
[/DefaultLightB@simulationScript:warning] the script is running in compatibility mode. It is highly recommended to switch to the new calling method, e.g.:
[/uarm@simulationScript:warning] module 'sim' was implicitly loaded.
[/uarm@simulationScript:info] Lua runtime error: ...iaSim_Edu_V4_9_0_rev6_Ubuntu20_04/lua/sim-deprecated.lua:191: attempt to yield from outside a coroutine
stack traceback:
[string "/uarm@simulationScript"]:411: in hook '?'
...iaSim_Edu_V4_9_0_rev6_Ubuntu20_04/lua/sim-deprecated.lua:191: in function 'sim-1.switchThread'
[string "/uarm@simulationScript"]:320: in function 'threadFunction'
[C]: in function 'xpcall'
[string "/uarm@simulationScript"]:411: in function 'sim_code_function_to_run'
[/uarm/uarm_base@simulationScript:error] [string "/uarm/uarm_base@simulationScript"]:375: bad argument #2 to 'format' (number expected, got nil)
stack traceback:
[C]: in function 'string.format'
[string "/uarm/uarm_base@simulationScript"]:375: in function 'sim_code_function_to_run'
[mainScript:error] [string "mainScript"]:74: attempt to call a nil value (global 'simResetMilling')
stack traceback:
[string "mainScript"]:74: in function 'sim_code_function_to_run'
Any guide would be appreciated.
