error message despite using eigen plugin
need2know
Post by need2know »
i work with the new eigen plugin for matrix calculation in my simulation project (v4.10) (therefore used the example inverseDynamics.ttt). Despite using the new plugin following warning message occurs:
[/Path/script:warning] module 'matrix' was implicitly loaded.
[/Path/script:warning] "matrix" module is deprecated. please use simEigen
Does the warning message apprears correct in this case?
______________________________________________________________
my code (found similar approach in the example inverseDynamics.ttt):
import('simEigen', '*')
local mMatrix = Matrix(math.floor(nNumberOfPoints),6,tData)
local tPositions = mMatrix:block(1,1,mMatrix:rows(),3):data()
Re: error message despite using eigen plugin
this is normal: previously, we had similar Matrix and Vector classes implicitly loaded. Many scripts still use that, thus the warning.
The better approach would be to explicitly use the Matrix and Vector classes from the simEigen module, like you are doing.
