How to set the simulation time dt through script of client?
Hacher
Post by Hacher »
The simulation velocity of dt can be changed in the 'simulation setup' dialog box, it's there any function like 'sim.startsimulation' that allow me to change the simulation velocity through script in the python client
Re: How to set the simulation time dt through script of client?
try with sim.setFloatProperty(sim.handle_scene, "timeStep", 0.01)
Just make sure simulation is not yet running.
Hacher
Post by Hacher »
Encounter an error when I try to use
Exception: 347: in sim.setFloatProperty: unknown property.
What CoppeliaSim version are you running? What does it print when you type:
sim.getProperties(sim.handle_scene)
Hacher
Post by Hacher »
The version I am using is 4.7.0, I encounter error:
AttributeError: type object 'sim' has no attribute 'getProperties'
If you want to change the timestep with versions prior to V4.9, use:
sim.setFloatParam(sim.floatparam_simulation_time_step, 0.01)
