need2know
Posts: 28 Joined: 29 Jul 2024, 09:53
Post
by need2know » 06 Oct 2025, 10:17
ive tried the urdf importer modul with an autogenerated urdf file.
It failed with following error:
[Importers >> URDF importer...@addOnScript:error] 88: in sim.genericFunctionHandler: object does not exist.
Source of the urdf:
https://github.com/ros-industrial/universal_robot
autogenerated urdf was send via mail.
Posts: 10808 Joined: 14 Dec 2012, 00:25
Post
by coppelia » 06 Oct 2025, 14:14
looking at the first external file in your u10e.urdf I see:
package://ur_e_description/meshes/ur10e/visual/base.stl
yet I can only find following file in th package:
ur_description/meshes/ur10e/visual/base.dae
am I missing something?
need2know
Post
by need2know » 06 Oct 2025, 15:59
thanks for your fast reply.
we found the problem: our intern folder structure was not correct -> urdf file has to be on the same structure level as the folder with the corresponding meshes.
