Dynamic modification of "solref" has no effect in MuJoCo engine
Marty
Post by Marty »
Hello everyone,
I’m facing a perplexing issue with MuJoCo’s solref parameters in a robotic arm force-control scenario, and I hope to clarify the contradiction I’ve observed to get targeted help.
Background
I’m simulating a scenario where:
    A robotic arm whose end effector maintains stable constant-force contact with a wall.
      The arm moves at a constant velocity along the X-axis while preserving this contact force
      What I Did
      I tested two scenarios for setting the wall’s MuJoCo "solref" parameters—with drastically different results:
        Static solref Setup (At Simulation Start)
        If I set the wall’s "solref" to my target values before starting the simulation, the behavior matches my expectation:
        The arm’s end effector loses stable contact once the simulation runs. Oscillations occur (as intended), confirming the solref values themselves are effective at disrupting constant-force stability.
          Dynamic solref Adjustment (Mid-Simulation)
          However, if I first let the simulation run normally (establishing stable constant-force contact for ~5 seconds), then use sim.setFloatArrayProperty() to adjust the wall’s "solref" to the exact same values as the static setup:
          The simulation shows no change whatsoever.
          The end effector continues to maintain stable constant-force contact, with no oscillations or force deviations—even though the parameter values are identical to the static scenario.
          What I’ve Verified So Far
            Engine & Object Validity: Confirmed the physics engine is set to MuJoCo (not ODE/Bullet), and the wall is a valid collision object (both Collisionable and Respondable enabled).
              Parameter Update Check: Used sim.getFloatArrayProperty() post-adjustment to confirm the wall’s solref values are updated to the target values mid-simulation.
                Force Control Logic: No changes were made to the arm’s force-control code between the two scenarios—only the timing of "solref" setup differs.
                System Info
                CoppeliaSim Version: 4.10
                Operating System: Windows 11
                Physics Engine: MuJoCo
                I can’t figure out why the "solref" adjustment isn’t affecting the simulation. Has anyone encountered a similar issue, or does anyone know potential reasons?
                Any suggestions or troubleshooting tips would be greatly appreciated. Thank you!
                Re: Dynamic modification of "solref" has no effect in MuJoCo engine
                firs make sure that the XML file generated reflects the SOLREF change you made. You can inspect the generated XML files in the folder you get with this command:
                sim.getStringProperty(sim.handle_app, 'mujocoPath')
                I suspect that your XML file simply isn't re-generated. A re-generation happens when e.g. you add/remove and object, change the scene hierarchy, inject XML code, or set the dynamic refresh flag. See also the following int property:
                sim.getIntProperty(sim.handle_scene, 'mujoco.rebuildTrigger')
                In your case, the easiest would be to call sim.resetDynamicObject upon the modified object.
                Marty
                Post by Marty »
                Thank you for your reply! Your suggestions really address my problems—I really appreciate it!
