Ngdk
Posts: 18 Joined: 17 Apr 2014, 14:26
Post
by Ngdk » 19 Apr 2014, 10:06
I am new in V-Rep, I'm installing and compiling v-rep following this tutorial
http://www.coppeliarobotics.com/helpFil ... ngVrep.htm , when I try to compile v_rep.pro file with qmake the output is following
Project MESSAGE: release
Project MESSAGE: Warning: unknown QT: printsupport
, then when I do "make" , the output bring me this error at the end
sourceCode/3dObjects/visionSensorObjectRelated/offscreenGlContext.h:32:26: fatal error: QOpenGLContext: No such file or directory
compilation terminated.
make: *** [propBrowser_engineProp_material.o] Error 1
. I don't know what is the problem because I'm following each step of tutorial.
Posts: 10378 Joined: 14 Dec 2012, 00:25
Post
by coppelia » 19 Apr 2014, 17:23
what version of Qt do you have installed?
If you do not compile for MacOSX, then you do not need the printsupport . But that should work fine on all platforms anyways.
The error message about QOpenGLContext should not happen if you are using Qt 5.0 or above.
Ngdk
Post
by Ngdk » 19 Apr 2014, 17:29
I've seen an other post with same problem and so I've compiled with Gt 5.2.0 but now I have this error
sourceCode/3dObjects/visionSensorObjectRelated/offscreenGlContext.h:33:29: fatal error: QOffscreenSurface: No such file or directory
when I open file
/offscreenGlContext.h there is already this include:
Post
by coppelia » 22 Apr 2014, 21:26
Sorry, I am at a loss here, Qt 5.2.0 should normally not produce that error...
Ngdk
Post
by Ngdk » 23 Apr 2014, 12:01
I've installed all again, now it's all right
