Shaking Robot
FelipeAcevedo
Shaking Robot
Post by FelipeAcevedo »
Hello
This is my first time using simulators in general and I'm having the following problem with the simulation
I have a quadruped robot only in "simple shapes" and 3 revolute joints per leg. The joints are set in torque/force mode and position controlled at 0°. But when I start the simulation to see if the robot can keep stand, it start to shake and bounce.
What should I look for to try solve this problem?
Thanks in advance
PS: Sorry for my bad english
Re: Shaking Robot
Hello Felipe,
Make sure you read this section of the user manual. It is very important regarding the dynamics of a simulation. In particular all the "design considerations".
FelipeAcevedo
Re: Shaking Robot
Thank you for your answer, it was very useful.
Finally I increased the large of the shapes (from ~4 cm to ~20 cm) and adjust the mass to 10:1 for the body and legs.
Now the joints only move between 0.07 and 0.08.
Thanks again
