I use Kubuntu 12.04 together with Cairo Dock. When I use V-Rep for about 10 minutes, quite a few ghost windows appear as seen in the right side of the screenshot, grouped together with the main window of V-Rep by Cairo Dock. I assume they are past UI dialogs. I wonder if anyone else is having this problem.
http://s7.postimage.org/vst83xm2j/ghost_windows.png
A lot of ghost windows appearing
Re: A lot of ghost windows appearing
This is a known issue with Kubuntu. We currently support and test Windows, MacOS and Ubuntu platforms. It is virtually impossible to test and adjust all the various Linux distributions for us. If you have some experience, could you try to compile v_rep and see if you can solve the problem? We would then try to add the modifications to the next releases.
