Maximum area supported
amattag
Contact:
Post by amattag »
Hello all,
Currently I am working in the simulation of a set of robots that must follow patrol missions in large scenarios.
I am very interested in using V-REP as the simulator, but I would like to know which is the maximum area in square meters
that a scenario can support in V-REP.
Many thanks for your help,
Antonio Matta.
Antonio Alejandro Matta Gómez.
Research Assistant - Robotics and Cybernetics Group.
Universidad Politécnica de Madrid.
Madrid, Spain.
Re: Maximum area supported
Hello Antonio,
There is no specific limitation in size. However:
  • Dynamic objects will only be active in a specific radius, counting from the origin. Refer to the variable "dynamicActivityRange" in file "system/usrset.txt" to adjust this radius
  • You can use very large maps. Make sure you adjust the camera's near/far clipping planes appropriately (if the near plane is too small compared to the far plane, you will experience OpenGl "Z-fighting")
amattag
Contact:
Post by amattag »
Thank you!
That sounds good to me!
Antonio.
