Python remote api: simxReadProximitySensor
rezama
Post by rezama »
I translated bubbleRobClient.cpp into equivalent python code as a stepping stone for writing my own client in python. When I run bubbleRobClient.py, the variable detectionState returned from simxReadProximitySensor is always evaluating to True. Is there any mistake in how I'm invoking the function?
Here is my implementation of bubbleRobClient.py:
import vrep
import sys
import time
print 'Program started'
portNb = 0
leftMotorHandle = 0
rightMotorHandle = 0
sensorHandle = 0
if len(sys.argv) >= 5:
    portNb = int(sys.argv[1])
    leftMotorHandle = int(sys.argv[2])
    rightMotorHandle = int(sys.argv[3])
    sensorHandle = int(sys.argv[4])
else:
    print "Indicate following arguments: 'portNumber leftMotorHandle rightMotorHandle sensorHandle'"
    time.sleep(5000.0 / 1000.0)
    sys.exit(0)
vrep.simxFinish(-1) # just in case, close all opened connections
clientID = vrep.simxStart('127.0.0.1', portNb, True, True, 2000, 5)
if clientID != -1:
    print 'Connected to remote API server'
    driveBackStartTime = -99000
    motorSpeeds = [0, 0]
    while vrep.simxGetConnectionId(clientID) != -1:
        (errorCode, detectionState, detectedPoint, detectedObjectHandle, detectedSurfaceNormalVector) = vrep.simxReadProximitySensor(clientID, sensorHandle, vrep.simx_opmode_streaming)
        if errorCode == vrep.simx_return_ok:
            simulationTime = vrep.simxGetLastCmdTime(clientID)
            if simulationTime - driveBackStartTime < 3000:
                motorSpeeds[0] = -3.1415 * 0.5
                motorSpeeds[1] = -3.1415 * 0.25
            else:
                motorSpeeds[0] = 3.1415
                motorSpeeds[1] = 3.1415
                if detectionState:
                    driveBackStartTime = simulationTime
            errorCode = vrep.simxSetJointTargetVelocity(clientID, leftMotorHandle, motorSpeeds[0], vrep.simx_opmode_oneshot)
            vrep.simxSetJointTargetVelocity(clientID, rightMotorHandle, motorSpeeds[1], vrep.simx_opmode_oneshot)
            if errorCode != vrep.simx_return_ok:
                print "SetJointTargetVelocity got error code: %s" % errorCode
        else:
            print "ReadProximitySensor got error code: %s" % errorCode
        time.sleep(5.0 / 1000.0)
    vrep.simxFinish(clientID)
else:
    print 'Failed connecting to remote API server'
print 'Program ended'
Here is how I am launching the python client from the lua script in scene file controlTypeExamples.ttt:
result = simLaunchExecutable("/usr/bin/python", "bubbleRobClient.py "..portNb.." "..leftMotor.." "..rightMotor.." "..noseSensor, 0)
v-rep version: edu 3.1.2 linux 64
Re: Python remote api: simxReadProximitySensor
yes, you are right, that bug was already corrected in the beta release of version 3.1.3.
Make sure to just replace the file vrep.py, since the official 3.1.3 version should be out in hopefully one day.
rezama
Post by rezama »
Thanks. I tried downloading the beta and running my code on it. I got the following error message. Thought I would share it, in case this is pointing to another bug that could be fixed before the release.
  File "bubbleRobClient.py", line 28, in <module>
    import vrep
  File "/home/reza/vrep64/vrep.py", line 44, in <module>
    c_GetJointPosition          = CFUNCTYPE(c_int32,c_int32, c_int32, POINTER(c_float), c_int32)(("simxGetJointPosition", libsimx))
AttributeError: ./remoteApi.so: undefined symbol: simxGetJointPosition
Simulator ended.
I cannot reproduce that error... please wait a few hours, the official release will be out in a few hours. Then try with that one.
rezama
Post by rezama »
I upgraded to 3.1.3 and I get the same error message. I have copied remoteApi.so to the root folder of v-rep so that libsimx = CDLL("./remoteApi.so") can succeed in the python code. This setup worked in 3.1.2.
are you sure you are using the correct library?
Can you try to recompile it? In programming/remoteApiBindings/lib, simply type make.
rezama
Post by rezama »
I compiled the library and the generated .so file was identical to the one shipped with v-rep.
I've been working with a clean installation of v-rep 3.1.3.
I've tested this on three different computers (both 32 bit and 64 bit) and I get the same error message. The systems I have used are all based on ubuntu 12.04.
lonchaneyjr
Post by lonchaneyjr »
I seem to have the same error with v-rep 3.1.3 on Ubuntu 14.04 64bit. I also tried recompiling the library, unfortunately with no success. Version 3.1.1 (the last one I used) worked fine.
you are both right!
This problem is only affecting the Linux (32 and 64) releases. The problem is that in the make file we somehow switched to g++, but gcc is needed. So you could recompile it by replacing g++ with gcc, or download the updated release (V3.1.3 rev. 2b) available now.
lonchaneyjr
That was fast, thanks!
Changing g++ to gcc and recompiling remoteApi.so fixed it for me (Ubuntu 14.04, 64-bit).
