Odometry and compass odometry pose estimate comparison
Post links to your CoppeliaSim videos, scenes and models
Eric
Post by Eric »
http://youtu.be/wLBwvDqBcuA?list=UU-OW0 ... 7pQNnoK4Lw
This video illustrates two dead reckoning pose estimations.
The blue robot is a differential drive robot (i.e. the ground truth). It is dynamically simulated so that wheels can slip.
The Red robot is a representation of the pose estimate based on pure odometry (data gathered from wheels rotation via "virtual" encoders.
The green robot is a representation of the pose estimate based on compass odometry. Compass odometry is using the perfect orientation reference instead of the estimate given by the wheels' encoders.
Balakrishnan1992
Re: Odometry and compass odometry pose estimate comparison
Post by Balakrishnan1992 »
I wish to find the orientation of a differential drive robot. Can I do the same with a compass in vrep. Where is the compass located ?(which library I mean)
Simply check the orientation of a given object with simGetObjectOrientation.
Balakrishnan1992
The thing is I am not allowed to use simgetobjectorientation on my robot. Is there another way to get the orientation without this ? I am afraid to wheel rotation to compute the heading because I am afraid about slippage. Can you suggest me a way to do this ??
If you need the exact orientation, then use simGetObjectOrientation. If you need a measured orientation like on the real robot, you will have to do odometry, and/or use some other sensors to extract an orientation.
