Line following bubbleRob tutorial
Hasif
Post by Hasif »
I am new to V-Rep and my final year project require me to understand this simulation software.
I tried the 'Line following BubbleRob' tutorial and copy paste the script.
Somehow. it seems that there are some errors on the script.
I ran the simulation but the bubbleRob doesn't seem to follow the line which it supposed to do and the bubbleRob keeps moving backwards.
Even the tutorial located in V-REP's installation folder, in tutorials/BubbleRob have the same problem when running the simulation.
I would like to know are there any mistakes in the script or are there any adjustments that the tutorial did not state even though I follow the tutorial closely?
Thanks.
Re: Line following bubbleRob tutorial
I guess you are running V-REP 3.1.3
There is a small bug that affects the behaviour of vision sensors that have a resolution of one-by-one pixel. A simply workaround is to set the resolution of the 3 vision sensors to 4-by-4. You can do this in the vision sensor properties.
Hasif
Post by Hasif »
Thank you.
It finally work.
