how to control the speed of servo motor?
I want to ask, how to control the speed of servo motor in V-Rep? Thank you
Re: how to control the speed of servo motor?
if your motor is controlled in position (motor enabled + control loop enabled), then you can adjust the item Upper velocity limit in the joint dynamic properties.
I have already checked the dynamics properties but my dynamics properties is different with the one that you have given to me.
What do you mean with "is different from the one you have given to me"?
