Lock a Joint / a Cuboid
qiushi.ji
Post by qiushi.ji » 25 Nov 2014, 08:40
Hi Marc,
I want to dynamically lock a joint in the simulation (just like a mechanical clamping in real world), that means for example a revolute joint would be locked with a infinitely force, it can't rotate anymore. Further more if I set it back, this joint could rotate again.
The second question is, how can I switch a cuboid property in the simulation between "static" an "static/respondable"`?
Cheers,
Ji
Re: Lock a Joint / a Cuboid
Post by coppelia » 25 Nov 2014, 10:38
Hello Ji,
in order to lock a joint you would switch the joint to a position control mode, maybe following two functions could be useful:
setJointToHoldPosition=function(jointHandle)
    simSetThreadAutomaticSwitch(false) -- only needed in a threaded child script
    simSetObjectIntParameter(jointHandle,2001,1) -- enable the control loop
    simSetJointTargetPosition(jointHandle,simGetJointPosition(jointHandle)) -- make sure we hold current position
    simSetThreadAutomaticSwitch(true) -- only needed in a threaded child script
setJointToVelocityControl=function(jointHandle)
    simSetObjectIntParameter(jointHandle,2001,0) -- disable the control loop
Optionally, if your joint motor is not enabled, you will also have to call simSetObjectIntParameter(jointHandle,2000,1) in the first function above, and simSetObjectIntParameter(jointHandle,2000,0) in the second function above.
For your second question, you would do this with:
simSetObjectIntParameter(shapeHandle,3004,respondableState) -- change the respondable state of the shape
simResetDynamicObject(shapeHandle) -- this call is needed in order for the previous command to take effect
qiushi.ji
Post by qiushi.ji » 25 Nov 2014, 11:47
thanks for the algorithm.
I have designed a simpler UI to switch this function, such like:
Lock_Joint=simGetObjectHandle('Revolute_joint')
buttonHandle,auxiliaryValues=simGetUIEventButton(Interface)
buttonprop_lock=simGetUIButtonProperty(Interface,28) --get prop of the function button
if sim_buttonproperty_isdown==simBoolAnd16(buttonprop_lock,sim_buttonproperty_isdown) then
	--lock function (downclick)******************************************
		setJointToHoldPosition=function(Lock_Joint)
   		simSetObjectIntParameter(Lock_Joint,2001,1) -- enable the control loop
   		simSetJointTargetPosition(Lock_Joint,simGetJointPosition(Lock_Joint)) -- hold current_pos
		Mode=simGetObjectIntParameter(Lock_Joint,2001) --get the current loop mode
		actPos=simGetJointPosition(Lock_Joint) --get the current pos
		simAddStatusbarMessage("Lock-On:  "..Mode.."   act_Pos:  "..actPos) --show info in Bar
	--unlock function (up click)**************************************
		setJointToVelocityControl=function(Lock_Joint)
			simSetObjectIntParameter(Lock_Joint,2001,0) -- disable the control loop
		simAddStatusbarMessage("Lock-Off:  "..Mode.."   act_Pos:  "..actPos) --show info in Bar
From the status bar I read the loop mode is always in "1", although I switching the button:
Lock-Off:  1   act_Pos:  -0.081999681890011
Lock-Off:  1   act_Pos:  -0.081979319453239
Lock-On:  1   act_Pos:  -0.081979319453239
Lock-On:  1   act_Pos:  -0.081960193812847
1, Should I set the joint property into Motor enabled and Control loop enabled before simulation start?
2, did I put the function code in the right if loop?
Or should I set a JointForce for holding a current position?
Post by coppelia » 25 Nov 2014, 18:57
You have defined functions to lock/unlock, but you are not calling them. At the same time, try to always define functions at the beginning of your script, not inside of some other block, since debugging will become very difficult otherwise.
