Threading in Vrep
AsadAli
Threading in Vrep
Post by AsadAli »
Hey Every one . I have a function written in a threaded Script i want to use it in such a way that whenever a sensor reads a value then if that value falls in the desired range then that function of the threaded script must be called .How can i do that . Its like a thread in C++ which in continuously keeping track of a particular change.
Any help will be really appriciated.
Eric
Re: Threading in Vrep
Post by Eric »
Hi
if the function you want to use is in the same threaded script as the rest of your code (i.e. where you read the sensor)
function myFunction(param)
	--do something
threadFunction=function()
 while 1 do
  --reading the sensor
  sensorVal,forceVector=simReadForceSensor(objectHandle)
  --checking if the force sensor val is falling into the range
  if forecVector[1]> triggerVal then
 	myFunction()
  simSwitchThread()
-- Put some initialization code here:
simSetThreadSwitchTiming(2) -- Default timing for automatic thread switching
-- Here we execute the regular thread code:
res,err=pcall(threadFunction)
if not res then
	simAddStatusbarMessage('Lua runtime error: '..err)
If the code that reads a proximity sensor (and the time it occurred) is in an other (non threaded) script and the threaded script with the function is in a separate script you can use for example signals to communicate within the scripts :
The non threaded script where the sensor is read:
	h=simGetObjectHandle('Proximity_sensor')
	--reading the proximity sensor
	sensorData=simReadProximitySensor(h)
	if sensorData==1 then --the sensor read something
		--sending the time of the reading through a signal
		simSetStringSignal('proxySignal',string.format('%i',simGetSystemTimeInMilliseconds()) )
The threaded script with the function:
	simAddStatusbarMessage(param)
	while 1 do
		 --reading the signal
		 sensorData=simGetStringSignal("proxySignal")
		 if sensorData~=nil then
			--we have some sata in the signal so we get it and clean it
			simClearStringSignal('proxiSignal')
			myFunction(sensorData)
		 simSwitchThread()
if not res then
Eric
AsadAli
Post by AsadAli »
When you define a function with ThreadFunction , what does that mean , Is it different from simple function definition in Vrep
it is just a function name. But in that case that function lives in a threaded child script, and you can stay inside the function until you stop the simulation (if you wish). You cannot do that in a non-threaded child script, otherwise the whole simulation blocks.
