getting v-rep to run
alphaUser
Post by alphaUser »
Dear Sir,
I have been trying to get V-REP running under Gentoo-Linux (64bit). I
have successfully downloaded the educational package and as well the
source code, and with some minor adjustments, got it to compile
through (qtcreator). Unfortunately, I do not now where to start from
here, since only a .so file seems to be build. When I start vrep from
the binary distribution and even if I let it load the new build
libv_rep.so it will fail stating:
Error: could not find or correctly load the V-REP library
Thank you and Regards!
Re: getting v-rep to run
Did you copy-and-paste the created library into the original V-REP PRO
EDU folder?
Make sure to copy all created libv_rep.so.* files into that directory.
You may have to recompile the client application (vrep). At the same
time, if libv_rep.so itself cannot find what it needs, the client
application cannot load it (e.g. the Lua libraries are required as well)
Try ldd libv_rep.so to see if something is missing.
alphaUser
Post by alphaUser »
Dear coppelia,
thanks for the quick reply!
I did exactly as you told me. The only library missing is
libpng12.so, since I have libpng15.so on my system. I symlinked it, so
ldd shows that it finds all librarys both on libv_rep.so as well as
vrep. Also I did an strace on vrep, but I could not find a sign where it
might fail. I attached it if you want to have a look at it.
How to I rebuild vrep?!
Thanks and Regards
alphaUser
Post by alphaUser »
Hello again,
I could resolve the issue. It all had to do with a missing libpng12 (as
I have libpng15). So installing libpng12 fixed the issue.
I am looking forward to work with the environment. Seems quite
promissing to me.
