Mimic Thrust Force Model - Cuboid
DannyYeong
Post by DannyYeong »
I'm trying to make a cuboid rise to a certain height and then stop. The cuboid should keep itself in air till the simulation ends. I'm using the simAddForceAndTorque command and I know that the force and torque are cumulative. How do I keep the object fixed at a certain height after rising?
Here's my model of build:
http://www.filedropper.com/thrustforcep ... uboidstest
Side question:
Do I use height comparison with a constant co-ordinate (example: {0,0,5} ) to adjust the force applied onto the cuboid?
It works like:
If cuboid reaches a a height of z= "5" (from 0,0,5), then the force applied will change. Else, keep rising.
Regards,
Danny
Re: Mimic Thrust Force Model - Cuboid
Hello Danny,
the forces/torques you apply with simAddForceAndTorque (or simAddForce) are cumulative in a given simulation step. But the cumulated force/torque will be cleared at the end of one simulation step.
But your approach is correct. I would implement a simple P controller for your force, instead of an on/off controller.
DannyYeong
coppelia wrote:Hello Danny,
I've tried using this coding:
simAddForceAndTorque(propeller,force,torque)
position1={0,0,0.5}
	if simGetObjectPosition(propeller,-1)>=position1 then
		force={0,0,0}
		torque={0,0,0}
		force={0,0,10}
		torque={0,0,0}
Apparently I can't compare <= or >= for a vector. I want to let it "float" itself on air after it reaches a specific height. However I could only use "==" or "~=", which is not the best option since the object will always surpass the specific height due to inertia, which keeps the object flying upwards. So how do I use the Z position as a variable to be compared with a fixed constant/threshold?
DannyYeong
position1={0,0,0.5}
		force={0,0,0}
		torque={0,0,0}
		force={0,0,10}
		torque={0,0,0}
Update to previous reply: I've found out how to refer the "Z" co-ordinate of the object, turns out I just have to define the object's position using
pos=simGetObjectPosition(propeller,-1)
and then use the Z co-ordinate by:
pos[3] -- the "3" refers to the 3rd vector, Z co-ordinate
My updated coding would be:
	propeller=simGetObjectHandle('Cuboid')
	ground={0,0,0} --ignore this for the moment
	pos1={0,0,0.5}
	if pos[3]<pos1[3] then
		force={0,0,10}
		torque={0,0,0}
		force={0,0,0}
here's the file: http://www.filedropper.com/thrustforcep ... oidstest_1
I wanted the object to stay in air while "bouncing about" (like a quadcopter rising motion to achieve balance in Z direction) but it keeps hitting the ground eventhough I've programmed it to apply force if the height drops a specific level. What coding I should use if the current one is not suitable or is there any add-on branch I should include in the ifelse case?
Regards,
Danny
You need to write a correct controller for your force. You also need drag (the D component of a PID controller). Maybe something like:
	local pos=simGetObjectPosition(propeller,-1)
	local accel=simGetArrayParameter(sim_arrayparam_gravity)
	-- cm is the proportional parameter of the PD controller:
	local cm=(pos1[3]-pos[3])/0.05
	if (cm>1.05) then cm=1.05 end
	if (cm<0) then cm=0 end
	-- str is the derivative paramter of the PD controller
	local str=-5 -- drag
	simAddForceAndTorque(propeller,{0,0,-accel[3]*cm})
	local linV,angV=simGetVelocity(propeller)
	local mass=simGetShapeMassAndInertia(propeller)
	local f={linV[1]*mass*str*cm,linV[2]*mass*str*cm,linV[3]*mass*str*cm}
	simAddForceAndTorque(propeller,f)
DannyYeong
coppelia wrote:You need to write a correct controller for your force. You also need drag (the D component of a PID controller). Maybe something like:
	local m=simGetObjectMatrix(propeller,-1)
	m[4]=0
	m[8]=0
	m[12]=0
	local mi=simGetInvertedMatrix(m)
	linV=simMultiplyVector(mi,linV)
	linV[1]=0
	linV=simMultiplyVector(m,linV)
Hi, I don't understand the Derivative part of the coding, added my comments into it below:
   m[4]=0
   m[8]=0
   m[12]=0
   linV[1]=0                                   -- ||||||||||||||||||why set the first value to 0?
   linV=simMultiplyVector(m,linV)    --  |||||||||||||||||Why multiplied?
You are right, the code was copy-pasted from another example, where the drag had to be relative to the shape frame, and only radial to it. See the updated version above.
DannyYeong
coppelia wrote:You are right, the code was copy-pasted from another example, where the drag had to be relative to the shape frame, and only radial to it. See the updated version above.
Might need some clarification on the 1.05 constant chosen, how it's that obtained?
DannyYeong
Found out for its reason, its just a self-made constant to provide a force more than the gravity force so it'll lift up. Thanks for the info provided. I tried my own, and apparently the Drag is really a problem. At this point of coding:
	grav=simGetArrayParameter(sim_arrayparam_gravity)
	diff=pos1[3]/pos[3] -- <1 shows over extended, >1 shows under extended
	if diff<1 then -- upward force
		f={0,0,-grav[3]*mass*0.99}
	if diff>1 then --downward force and to prevent drag force
		f={0,0,-grav[3]*mass*1.01}
I decided to use division instead of minus and multiplying like the coding provided earlier. My file is here:
The object is currently being dragged up but it exceeds the height and then drops. After the first process, the object goes up and down by alittle to balance itself. However, onwards process seems to go higher and more lower than the first cycle. Is this caused by the drag? If so, could I try a different approach to control the drag using another way other than velocity?
You are using a simple 2-state controller. Either you apply a force of X, or a force of Y. It is normal that your control won't be good. You will have to use something more sofisticated, at least a P/PD controller. You will have to try.
