Haptic Data Retrieve
Hello. I have a Haptic device and I have installed all the support softwares. Now I want to retrieve Haptic tip position from v-rep child script to matlab using simxgetsignal. I want to know where where can I find current position of TIP of Haptic device in child script. I want to know the exact variable where the data stored.
I have attached the URL for Haptic device TIP location
http://public.vrac.iastate.edu/~chardin ... mage_2.jpg
Re: Haptic Data Retrieve
you can use simExtCHAI3D_readPosition(deviceIndex).
You can get some code inspiration from following two examples (check the attached child scripts):
- Models/other/Interface to haptic device.ttm
- Scenes/hapticRobot.ttt
Hello
I don't know why my haptic interface is not working. I have connected the haptic device and I have glut file along with CHAI3D plugin in v_rep directory. It's showing something wrong and in RED color window without any message.
Even I tried both way. 1- with model/other/haptic device
2. with Haptic Robot .ttt file
help me to solve this problem......
What does the console window say? Is the plugin correctly loaded?
there is no message on the console window. it has only one button with OK message. I'm using Geomagic Touch phantom device. I'm not sure about the plugin. I have put the plugin that is provided by Coppelia on request. even I have glut file in the directory.
There are always messages in the console, e.g. to tell which plugin was loaded or to output other type of informations.
On Windows, go to the user settings and uncheck hide console window.
Now in console window I can see that the CHAI3D plugin is loaded and other plugin also...
Have you tested your haptic device with any other application, to see if that works fine?
When you execute the demo model, what kind of output can you see in the status bar? Any error message (e.g. initialization failed, etc.)?
Yes I tried to test the haptic device with 'Geomagic Touch Diagnostic' tool. I tried to get force feedback and tip position in this tool. I'm using windows and v_rep. I have glut32.dll and v_repExtCHAI3D.dll in my v_rep directory. I have calibrated the device also. Now I'm trying to interface the haptic device with v_rep and nothing else. I am attaching the image url of console window and main window with messages...
![Image](https://plus.google.com/u/0/+PrasannaRoutray97/posts/4Z1URkzCKN2?pid=6161656047666410658&oid=110126485418398595678)
![Image](https://plus.google.com/u/0/+PrasannaRoutray97/posts/4Z1URkzCKN2?pid=6161656044149803570&oid=110126485418398595678)
Sorry for the wrong method in posting Image URL.
https://plus.google.com/u/0/+PrasannaRo ... 8398595678
