Hexapod legs collision
osm3000
Post by osm3000 »
I'm using the ant-hexapod model in V-REP with an evolutionary optimization algorithm to achieve fast gaits. Some gaits lead to the legs of the hexapod to collide or get over each other, leading to a very rough movement.
I want to know allow the legs to 'cut' each other fine without colliding with each other. I don't want to limit the parameters of my evolutionary algorithm, just directly modifying the simulator.
Kind Regards
Omar
Re: Hexapod legs collision
Hello Omar,
so you want to disable collision inside of the model itself? For that, set all the local respondable masks to 0 for all your dynamically enabled objects in the hexapod model.
osm3000
Post by osm3000 »
Perfect! Works fine.
Many thanks for the help.
