issue with simReadJointPosition() and simPackXXXX()
jesusmartinb
Post by jesusmartinb »
I'm a beginner in V-Rep, I´m trying to send information between V-REP and Simulink and I can do it with the funtion simReadForceSensor because I know that I get two float vector with 3 arguments each, and I have no problem when I pack this data and send to Simulink but, if i want to do the same with the funtion simReadJointPosition, I don´t know what type of data I´m working and their size neither so, when i try to do it in the same way I get this error.
Lua API call error: [string "SCRIPT vrepTorque"]:58: One of the function's argument type is not correct. (simPackFloats)
Lua API call error: [string "SCRIPT vrepTorque"]:59: Wrong argument type/size. (simExtShareMemoryWrite)
	id=tonumber(simGetScriptSimulationParameter(sim_handle_self,"id Torque"))
	FL=simGetObjectHandle('vrepTorque')
	hip_right=simGetObjectHandle('right_HIP_FL_joint')
	graph=simGetObjectHandle('right_HIP_Torque')
	graph2=simGetObjectHandle('right_HIP_Position')
	sensor=simGetObjectHandle('right_HIP_Force_sensor')
	result,floatMem_IN  =simExtShareMemoryOpen("vrepTorque_entrada_1",3*4*2)
	result,floatMem_OUT  =simExtShareMemoryOpen("vrepTorque_salida_1",3*4*2)
--Add torque around joint
	vector={0.0, 0.0, 0.0}
	result,data=simExtShareMemoryRead(floatMem_IN)
	vector=simUnpackFloats(data,0,3)
	print("ParHR[1]: "..vector[1].."  ParHR[2]: "..vector[2].."  ParHR[3]: "..vector[3])
	simAddForceAndTorque(FL, nil, vector)
--Reads the force
	result,TableForce,torqueVector=simReadForceSensor(sensor)
--Reads the position
	position = simGetJointPosition(hip_right) -- este angulo es el que quiero mandar a Simulink
--represent final aplied torque and position
	simSetGraphUserData  (graph,'torqueDeseado',vector[2])
	simSetGraphUserData (graph,'torqueFinal',-torqueVector[3])
--Send aplied torque to Simulink
	print("ParRealHR[1]: "..-torqueVector[1].."  ParRealHR[2]: "..-torqueVector[2].."  ParRealHR[3]: "..-torqueVector[3])
	torqueFinal={0, -torqueVector[3], 0}
	data=simPackFloats(position,0,2)
	result=simExtShareMemoryWrite(floatMem_OUT,data)
	-- Put your main SENSING code here
	simExtShareMemoryClose();
Re: issue with simReadJointPosition() and simPackXXXX()
not sure about the whole code, but following can't work:
The reason is that simPackFloats expects a table of float values for the first argument. But your first argument is a number (not a table). So try with following code instead:
data=simPackFloats({position})
In above case, the table just contains one value (one float) that you pack into a string. On the simulink side, you will have to unpack that string as a single float.
avico23
Post by avico23 »
Hi jesusmartinb,
Can you please show what you used on the simulink side.
and what kind of code or blocks you are using inside of simulink.
Thanks,
Avi
