Does V-Rep supports such kind of joystick: 3DConnexion
jacobi
Post by jacobi »
As Coppelia said in another thread:
coppelia wrote:On the Windows version there should be a readily available Joystick interface. Check functions:
	local joysticCount=simExtJoyGetCount()
	local axes_3,nuttons,rotAxes_3,sliders_2,pov_4=simExtJoyGetData(joysticZeroBasedIndex)
Check also its source code in programming/windowsOnlyProjects/v_repExtJoystick
With ROS, you can use programming/ros_packages/vrep_joy
Or of course do it yourself by interfacing via plugin or the remote API an existing library.
I wonder if any one have tested if the v_repExtJoystick supports 3DConnexion.
Since I cannot find 3DConnexion in the forum. So I create this new post as a placeholder, in case others share the same interest.
Many thanks!
Re: Does V-Rep supports such kind of joystick: 3DConnexion
that plugin doesn't support 3D mouses, but I know that some have created a Python interface to V-REP, using one common Python lib, can't remember right now, now where you can find it. Sorry, I just realize that doesn't sound very helpful.
jacobi
Post by jacobi »
Thanks for your prompt reply.
I found in the 3dConnexion forum a topic on comparing DI with the 3DxWare driver.
http://www.3dconnexion.com/forum/viewtopic.php?t=1610
I have sent them an email to request the DI examples, and I hope I can get it.
If it will be too hard, then I prefer to use the 3DxWare and give another try.
There is a Python library called Pygame that uses SDL, that apparently supports that type of input devices.
For instance:
pygame.joystick.get_count()
joystick1=pygame.joystick.Joystick(0)
axisX=joystick1.get_axis(x)
buttonX=joystick1.get_button(x)
Haven't tried it however. But I know that some use it to read out a space mouse and send the data to V-REP via the remote API.
The better approach however is via a plugin like you suggested. We can assist you with the plugin for the V-REP-side related things, if you wish.
jacobi
Post by jacobi »
Thanks, I will try to test the Lua bindings for SDL and give a report later.
Lua
Lua-SDL2 - https://github.com/Tangent128/luasdl2
oh, great, that's even better. Didn't know about that Lua extension library!
Keep us updated if possible.
Hello Tobi,
we haven't tried it ourselves, but we know that it works fine, from a customer that did it (on Windows, too).
Tobias
Post by Tobias »
Ok, sounds good. I will try it.
Cheers,Tobi
