UnsatisfiedLinkError Mac OS by calling simxStart
BrainDead
Re: UnsatisfiedLinkError Mac OS by calling simxStart
Post by BrainDead »
Here is a helpful link to understand the problem using eclipse:
http://mindprod.com/jgloss/runerrormess ... DLINKERROR
Put your sources into dafault package or make the *.h fully qualified.
bnewman
Post by bnewman »
After Upgrading to 3.0.4, on OSX I have started to receive this error again. I did a make clean and remake on remoteApiSharedLibJava_Makefile, but still receive the error.
Exception in thread "main" java.lang.UnsatisfiedLinkError: coppelia.remoteApi.simxStart(Ljava/lang/String;IZZII)I
	at coppelia.remoteApi.simxStart(Native Method)
	at simpleTest.<init>(simpleTest.java:62)
	at simpleTest.main(simpleTest.java:213)
Is it possible the libremoteApiJava.dylib needs to be updated? The last one I have is from the zip file I found here.
These files are located in my java path.
  • libremoteApiJava
    remoteApi
    remoteApiJava
What could be causing this issue?
Billy
Hello Billy,
Are you sure the folder coppelia is also in the search path of Java? Since V-REP 3.0.4 all the functions are packaged inside coppelia.
Is the example application programming/Java/simpleTest.java working?
And make sure to use the libRemoteApiJava.dylib that comes with the last V-REP release (V3.0.4)
bnewman
Post by bnewman »
Sorry for the hassle, but I am unable to find libRemoteApiJava.dylib in any of the program/directories associated with VREP. When I make remoteApiSharedLibJava_Makefile, it only produces remoteApiJava.dylib.
simpleTest.java does not run, although I did run before upgrading.
Billy
I was able to get it working by renaming remoteApiJava.dylib to libremoteApiJava.dylib
Thank you for your help.
Ooops, you are right, I meant to refer to the file programming/remoteApiSharedLib/remoteApiJava.dylib. Sorry about that.
