Consider two Cases:Design consideration 7
Keep masses similar and not too light. When linking two shapes with a dynamically enabled joint or a dynamically enabled force sensor, make sure the two shape's masses are not too different (m1<10*m2 and m2<10*m1), otherwise the joint or force sensor might be very soft and wobbly and present large positional/orientational errors (this effect can however also be used as a natural damping sometimes). Additionally, very low mass shapes should be avoided since they won't be able to exert very large forces onto other shapes (even if propelled by high force actuators!).
Case A:
100kg mass
>Joint
>>5kg mass
Case B:
50kg mass
>Force Sensor
>>50kg mass
>>>Joint
>>>>5kg mass
My question is, say we broke an original 100kg mass into two 50kg masses connected by a force sensor, would this produce a better behaviour for the simulation? Ie., would Case A perform more stably than Case B?
