Data Steam Recording List Details
Wilsonator
Post by Wilsonator »
Under data stream recording list when using a Graph we can add new data streams. When we add data streams a new item is added to the list which shows the object name in brackets; however there seems to be no indicator of which data stream type was selected.
Would it be possible to add the data stream type to the bracketed information?
i.e. for an object called "Sphere"
currently: Data[Sphere]
Suggested: Data[Sphere - Object: absolute x-position]
If you can think of a better way to indicate this information that would also be great! Currently you just have to remember which data type you used, then immediately change the name of the list entry to avoid forgetting later on. If you do forget to change the name, only way to be sure is to delete the data stream entry and remake the data stream entry.
Re: Data Steam Recording List Details
Good suggestion. Done!
