How do I plot acceleration of joints/links for my robot
Shinji3000
Post by Shinji3000 »
I ran the simulation scene and have plotted velocity graphs for each joint. Now I want to plot acceleration for these joints.
I couldnt find Joint:acceleration in "Data stream type".
Please help me how to plot acceleration graph for joint/link.
This is in IK module.
Regards,
Re: How do I plot acceleration of joints/links for my robot
in the graph properties, select the velocity data stream item, then select Derivative instead of Raw in the combobox below.
Fery64
Post by Fery64 »
The answer is not clear, I also wanted to do the same, but I do not see the option raw or derivative when I open the Graph properties window !
https://tinypic.host/i/raw.yoyvp
the original post is from 6 years ago. CoppeliaSim has greatly improved since then. Now, most things can/should be done programmatically. Some of the old dialogs can be still displayed with following temporary trick (not recommended):
In file usrset.txt, set or add an entry with:
showOldDlgs=true
You can find the location of usrset.txt by typing sim.getStringParam(sim.stringparam_usersettingsdir)
Much better would be to the things the new way. For that, have a look at the graph page for a quick overview. For transformation of the data, you can either provide already transformed data to sim.setGraphStreamValue, or you can set a transformation type with sim.setGraphStreamTransformation.
