Color Integration For simImportMesh in Regular-API
smeissne
Post by smeissne »
currently I'm working on a Plugin which allows you to import an OpenStreetMap map to generate a 3D V-Rep Scene. My 3D street objects, like houses and trees, are saved in an *.obj file and imported by the simImportMesh() function of the Regular API. If I do the import manually then colors are correctly defined. Using the Regular API all colors are set randomly and have to be changed manually like:
simSetShapeColor(shapeHandle,"",sim_colorcomponent_ambient,grey);
Is there a way to import the the color information from the *.obj.mtl file like the frontend function does? I think results would look quiet better.
Thank you and kind regards,
Sören
Re: Color Integration For simImportMesh in Regular-API
Hello Sören,
this looks interesting!
Have you tried with simImportShape? This will however directly create the shape objects.
Let me know,
atom
Post by atom »
Hi Sören,
I'm trying to achieve the same functionality but a much basic version, i wanted to import OSM roads into V-rep, can i know of the progress of your project? Any help is much appreciated.
Thanks,
atom.
