Hokuyo_URG_04LX_UG01_ROS with rosInterface.
sradmard
Post by sradmard »
I am trying to implement a rosInterface version of Hokuyo_URG_04LX_UG01_ROS sensor so that it uses rosInterface instead of rosPlugin. I would really appreciate if you can advice me on how to do it, or where I can get the attributes of the sensor so that I can define all of the fields of sensor_msgs/LaserScan message type.
Thank you so much in advance.
sradmard
Re: Hokuyo_URG_04LX_UG01_ROS with rosInterface.
Post by sradmard »
I was wondering whether anybody has found the answer or knows where to find the attributes of the sensor.
what field elements do you need for your message? The whole operation of the Hokuyo is defined in its attached child script. Beware that the Hokuyo URG 04LX UG01_ROS.ttm model is based on a proximity sensor attached to a joint. This type of sensor is most of the time slower than scanners that are based on vision sensors (e.g. Hokuyo URG 04LX UG01_FAST.ttm
karmeluk
Post by karmeluk »
I have the same trouble.
The suggested by you sensor model "Hokuyo URG 04LX UG01_ROS.ttm" is based on RosPlugin instead of RosInterFace. So I didn't find any example how to publish correct LaserScan message to ROS topic.
My VREP version is 3.5.0 and it seems like precompiled RosPlugin '.so' lib and its source files to compile do not included there.
Currently I am facing with putting a full LaserScan message into publisher.
In included example (it is for RosPlugin (!) as was already mentioned) sensing is implemented in 'sysCall_sensing()' function and sent as a signal:
    -- Now send the data:
    if #points>0 then
        table.insert(dists,-scanRange*0.5)  --append angle_min to [ranges]
        table.insert(dists,scanRange*0.5-stepSize) --append angle_max to [ranges]
        table.insert(dists,stepSize) --append stepsize to [ranges]
        -- The publisher defined further up uses the data stored in signal 'rangeDat'..objName
        sim.setStringSignal('rangeDat'..objName,sim.packFloatTable(dists))
Next it is handled by rosPlugin publisher:
topicName=simExtROS_enablePublisher('front_scan',1,simros_strmcmd_get_laser_scanner_data ,modelHandle,-1,'rangeDat'..objName)
where main conversion was prepared by 'simros_strmcmd_get_laser_scanner_data' function which is currently unavailable. It did not find any API or implementation description for this.
I am trying to do it with rosInterface in accordance to included in 3.5.0 release examples as recommended by you and currently the only possible way :
keep sensing as it is with sending as '''rangeDat'..objName" signal:
function sysCall_sensing()
    showLaserPoints=sim.getScriptSimulationParameter(sim.handle_self,'showLaserPoints')
    showLaserSegments=sim.getScriptSimulationParameter(sim.handle_self,'showLaserSegments')
    dists={}
    angle=-scanRange*0.5
    sim.setJointPosition(jointHandle,angle)
    jointPos=angle
    laserOrigin=sim.getObjectPosition(jointHandle,-1)
    modelInverseMatrix=simGetInvertedMatrix(sim.getObjectMatrix(modelRef,-1))
    for ind=0,pts-1,1 do
        r,dist,pt=sim.handleProximitySensor(laserHandle) -- pt is relative to the laser ray! (rotating!)
        m=sim.getObjectMatrix(laserHandle,-1)
        if r>0 then
            dists[ind]=dist
            -- We put the RELATIVE coordinate of that point into the table that we will return:
            ptAbsolute=sim.multiplyVector(m,pt)
            ptRelative=sim.multiplyVector(modelInverseMatrix,ptAbsolute)
            points[3*ind+1]=ptRelative[1]
            points[3*ind+2]=ptRelative[2]
            points[3*ind+3]=ptRelative[3]
            segments[7*ind+7]=1 -- indicates a valid point
            dists[ind]=0
            -- If we didn't detect anything, we specify (0,0,0) for the coordinates:
            ptAbsolute=sim.multiplyVector(m,{0,0,6})
            points[3*ind+1]=0
            points[3*ind+2]=0
            points[3*ind+3]=0
            segments[7*ind+7]=0 -- indicates an invalid point
        segments[7*ind+1]=laserOrigin[1]
        segments[7*ind+2]=laserOrigin[2]
        segments[7*ind+3]=laserOrigin[3]
        segments[7*ind+4]=ptAbsolute[1]
        segments[7*ind+5]=ptAbsolute[2]
        segments[7*ind+6]=ptAbsolute[3]
        ind=ind+1
        angle=angle+stepSize
        jointPos=jointPos+stepSize
        sim.setJointPosition(jointHandle,jointPos)
    sim.addDrawingObjectItem(lines100,nil)
    sim.addDrawingObjectItem(points100,nil)
    if (showLaserPoints or showLaserSegments) then
        t={0,0,0,0,0,0}
        for i=0,pts-1,1 do
            t[1]=segments[7*i+4]
            t[2]=segments[7*i+5]
            t[3]=segments[7*i+6]
            t[4]=segments[7*i+1]
            t[5]=segments[7*i+2]
            t[6]=segments[7*i+3]
            if showLaserSegments then
                sim.addDrawingObjectItem(lines100,t)
            if (showLaserPoints and segments[7*i+7]~=0)then
                sim.addDrawingObjectItem(points100,t)
    if #points>0 then
initiate publisher inside of sysCall_init()
hokuyoPub = simROS.advertise('/scan','sensor_msgs/LaserScan')
then in sysCall_actuation() publish messages:
I have tried three different cases:
1)
function sysCall_actuation()
    local laser_scan = sim.getStringSignal('rangeDat'..objName)
        if laser_scan then
            local laser_scan=sim.unpackFloatTable(laser_scan)
            simROS.publish(hokuyoPub, laser_scan) -- and with {laser_scan}
error is:
Lua runtime error: [string "CHILD SCRIPT Hokuyo_URG_04LX_UG01_ROS"]:62: read__sensor_msgs__LaserScan: expected a table (simROS.publish @ 'RosInterface' plugin)
stack traceback:
[C]: in function 'publish'
[string "CHILD SCRIPT Hokuyo_URG_04LX_UG01_ROS"]:62: in function <[string "CHILD SCRIPT Hokuyo_URG_04LX_UG01_ROS"]:58>
2)
        if laser_scan then
            simROS.publish(hokuyoPub, {msg=sim.unpackFloatTable(laser_scan)})
and getting following error:
ua runtime error: [string "CHILD SCRIPT Hokuyo_URG_04LX_UG01_ROS"]:61: read__sensor_msgs__LaserScan: unexpected key: msg (simROS.publish @ 'RosInterface' plugin)
stack traceback:
[string "CHILD SCRIPT Hokuyo_URG_04LX_UG01_ROS"]:61: in function <[string "CHILD SCRIPT Hokuyo_URG_04LX_UG01_ROS"]:58>
Simulation stopped.
3) use 'ranges' field
        if laser_scan then
            simROS.publish(hokuyoPub, {ranges=sim.unpackFloatTable(laser_scan)})
causes no error but incorrect messages (sniffed by 'rostopic echo /scan'):
header:
seq: 147
stamp:
secs: 0
nsecs: 0
frame_id: ''
angle_min: 0.0
angle_max: 0.0
angle_increment: 0.0
time_increment: 0.0
scan_time: 0.0
range_min: 0.0
range_max: 0.0
ranges: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, -2.356194496154785, 2.3500585556030273, 0.006135923322290182]
intensities: []
Another thing is how to publish TF together with LaserScan?
Thanks in advance!
/Andy
in what sense the message is "incorrect"?
karmeluk
Post by karmeluk »
Because it is empty, even angle parameters. The only 3 incorrect (because as far as I understand LaserScan message and physics it cannot be negative) values in the end of 'ranges' array are present.
I have scene with many different obstacles and expecting LaserScan message fulfilled: : http://docs.ros.org/api/sensor_msgs/htm ... rScan.html
You are not setting any message fields.
You have to create the message in Lua according to the message specification, e.g.:
msg={
    header={
        timestamp=...,
        frame_id=...,
    angle_min=...,
    angle_max=...,
    angle_increment=...,
    time_increment=...,
    scan_time=...,
    range_min=...,
    range_max=...,
    ranges=[....],
    intensities=[...]
and then call:
simROS.publish(hokuyoPub, msg)
matheus.pinto
Post by matheus.pinto »
Does anyone have a code sample?
Medo BKB
Post by Medo BKB »
hello fferri
if you don't mind how can i set those message fields in lua script
thank you
This:
fferri wrote:
28 Apr 2018, 16:35
msg={
    header={
        timestamp=...,
        frame_id=...,
    angle_min=...,
    angle_max=...,
    time_increment=...,
    scan_time=...,
    range_min=...,
    range_max=...,
    ranges=[....],
    intensities=[...]
is actual Lua code. Replace ... with actual values (numbers, strings).
