bubbleRob moving weird
ssj
Post by ssj »
hello
I m new to vrep. i have started with the tutorial bubbleRob. i ve followed the tutorial religiously. everything is working fine except bubbleRob. in any case it rotates and does not move straight . either i set velocity to one of the wheel or both.
Re: bubbleRob moving weird
can you post the scene? It will be easier to find out what is going on.
ssj
Post by ssj »
hey i solved that. thanks.
i am try to build my own multi platform robot now. but whenever i start simulation it disintegrates into components. please help :(
how can i send you my scene file?
Please post a link to a dropBox file (or similar).
If your robot desintegrates, it either has many self-collisions, or it is not build according to this page.
Looking at your model... your platforms are way too light (1 gram) (and have a too small inertia), compared with the wheels (1.23 Kg). Simply multiply the mass and inertia of those platforms by approximately 1000 and things will be much better.
Make sure to carefully read this page when designing dynamic simulations.
ssj
Post by ssj »
Thank you for your response. I ve tried to manage the weight of robot platform and wheels. it is relatively stable now. but when i start simulation, wheels rotate but the body does not move forward. additionally it tilts towards one side. please help.
here is the link of my file https://drive.google.com/open?id=0B6Fmg ... 3ZGQTEtMDA
This is perfectly normal: you have two wheels (left and right) and two contact points (front and back). So you basically have 4 contact points and you have a hyperstatic situation. On top of that you managed to place the 4 items (2 wheels and 2 spheres) so that their contact with the floor does not lie on one plane.
You have two possibilities:
  • Move one of the spheres slightly up, so that the two wheels touch the floor at all times. YOu will then have some slight tilting from back to front.
  • The better solution is to perform above point 1, and to attach one of the spheres to a spring-damper. This way you won't have a hyperstatic situation anymore.
ssj
Post by ssj »
hey it works. Thanks.
now I have attached another base above the existing base using 4 joint between them. unfortunately when i start simulation, the upper layer falls down on the lower layer :( moreover the icons appear against these 4 joints, showing message that joints are not dynamically enabled.
what should i do?
Please post your scene.
