Passing the path to scene file as command line argument
Pouya
Post by Pouya »
Hello all.
In our lab we mostly use v-rep for developing plugins and one feature that we are missing a lot, is possibility to launch v-rep and automatically load a scene. E.g. something like this:
./vrep -f myscene.ttt
So that when v-rep is launched, it opens myscene.ttt instead of an empty environment.
Re: Passing the path to scene file as command line argument
You can already do that, but you will have to leave out the -f argument, so on Linux, typically:
./vrep.sh scenes/myScene.ttt
Will load the file located in the relative path scenes/myScene.ttt. You can also specify an absolute path.
basti35
Post by basti35 »
this is my first post, so first of all I want to thanks all the coppelia team for your work. It's great!
I found that relative path have to be relative to the vrep install dir. Usually we have scenes that have to be aligned with some project versioning system, so it's unlikely that they are archived in the vrep install dir folder. I would like to have the possibility of launching scenes from their relative path.
I took some time to propose you a patch for the vrep.sh file. It checks if there is a scenes relative to the user working directory, make it absolute (by appending the relative path to the given scene). This is the diff:
15,24c15
< if [ -f $1 ]
< then
<   if [ -f "$PWD/$1" ]
<   then
<     SCENE="$PWD/$1 "
<     shift
<   fi
< fi
< LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$dirname
> LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$dirname"
26c17,19
< "$dirname/$appname" ${SCENE}${1+"$@"}
> "$dirname/$appname" "$@"
And this is the resulting script
#!/bin/sh
thisscript="$0"
while [ -L "$thisscript" ]; do
        thisscript="`readlink "$thisscript"`"
done
dirname=`dirname "$thisscript"`
if [ $dirname = "." ]; then
        dirname="$PWD"
fi
appname="`basename "$thisscript" | sed 's,\.sh$,,'`"
if [ -f $1 ]
then
  if [ -f "$PWD/$1" ]
  then
    SCENE="$PWD/$1 "
    shift
  fi
fi
export LD_LIBRARY_PATH
Nothing else is changed but the fact that if the scene file exists with a path relative to the user working directory, the user working directory is added. Every other parameter is left as it was.
If the file does not exist as relative, $SCENE will be empty. Otherwise, it will contain the absolute path plus a space, to separate it from the other parameters (${1+"$@"}) when recalling them in the last command.
I hope it can be useful to someone.
Thanks for the input!
there is the additional difficulty that there can be other types of arguments, not just a file to load, and the order can be any.
basti35
Post by basti35 »
With sh this becomes more difficult (probably require a lot of shifts to modify the exact arguments. With bash the following solution should work.
#!/bin/bash
thisscript="$0"
done
        dirname="$PWD"
fi
PARAMETERS=( ${@} )
FILE_PATTERN='*ttt'
for i in `seq 0 $(( ${#PARAMETERS[@]} -1 ))`
do
  if [ -f "${PARAMETERS[$i]}" ] && [[ "${PARAMETERS[$i]}" == $FILE_PATTERN ]]
  then
    if [ -f "$PWD/${PARAMETERS[$i]}" ]
    then
      PARAMETERS[$i]="$PWD/${PARAMETERS[$i]}"
    fi
  fi
done
"$dirname/$appname" "${PARAMETERS[@]}"
I put all the received arguments in PARAMETERS array. Then only the one which contains a path to an existing file and ends with ".ttt" are modified by adding the current working dir.
That's perfect, thanks a lot!
