Error: signal 11
Jevgenerus
Error: signal 11
Post by Jevgenerus » 23 Aug 2018, 02:59
I have freshly installed Ubuntu 18.04 LTS version and downloaded the latest version of V-REP Pro Edu (3.5.0) from the website.
When I try to run V-REP by using "./vrep.sh" command I get the following error:
~/Programs/V-REP_PRO_EDU_V3_5_0_Linux$ ./vrep.sh
Error: signal 11:
libv_rep.so(_Z11_segHandleri+0x28)[0x7fec3236f0c8]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fec36499f20]
/lib/x86_64-linux-gnu/libc.so.6(+0x49ac3)[0x7fec364a4ac3]
libv_rep.so(_ZN6oglExt15_isFboAvailableERb+0x1d)[0x7fec3256ea4d]
libv_rep.so(_ZN6oglExt25prepareExtensionFunctionsEb+0x1a)[0x7fec3256eada]
libv_rep.so(_Z15initGl_ifNeededv+0x59)[0x7fec32516769]
libv_rep.so(_ZN11CMainWindowC2Ev+0x854)[0x7fec328344e4]
libv_rep.so(_ZN3App16createMainWindowEv+0x44)[0x7fec3250aea4]
libv_rep.so(_Z24simRunSimulator_internalPKciPFvvES2_S2_+0x265)[0x7fec3237c725]
/home/jev/Programs/V-REP_PRO_EDU_V3_5_0_Linux/vrep[0x4020f2]
I have found a few topics with similar issues here on forum:
In this one it was suggested to check graphics driver, however I assume it is not my case, since I have the newest driver installed for my videocard.
Second one seems more similar to my case, from which it looks that I cannot run V-REP on Ubuntu version 18.
What can cause this problem? And do I have to reinstall OS to be Ubuntu ver. 16 or is there any workaround?
Thanks,
Jevgeni
Re: Error: signal 11
Post by fferri » 27 Aug 2018, 07:35
One thing you could try is to download and install a Qt version which supports Ubuntu 18, and compile V-REP from source.
Jevgenerus
Post by Jevgenerus » 05 Sep 2018, 00:24
Thanks for the answer!
If I get correct, first I should install Qt software from this website: https://www.qt.io/download
For compiling from source - I understood that:
Before compiling:
0) I should install QScintilla2, Boost C++ library and Lua 5.1 (binaries and headers)
For compiling:
1) I should download and install V-REP PRO EDU (like normally)
2) Then I should download source code of V-REP and plugins into V-REP folder.
3) "Finally, before being able to compile the V-REP project, you will have to adjust various paths in the config.pri file."
- should I adjust paths here in some specific way?
4) "The easiest for you to do is to copy the compiled libraries into the V-REP PRO or V-REP PRO EDU folder, then you will be sure that V-REP should start and won't complain about missing dependencies."
-- do the libraries here mean Boost C++ library/source codes/something else?
Is the sequence correct and what do I supposed to do in steps 3 and 4?
Sorry for these silly questions, I am just encountering with these things for first time.
Thanks,
Jevgeni
Post by fferri » 05 Sep 2018, 08:08
Jevgenerus wrote:
05 Sep 2018, 00:24
Before compiling:
yes, you should have packages for most of these dependencies, but you will need to manually download the source code of QScintilla2, unpack it somewhere, and compile it, because V-REP will use some private QScintilla2 headers
Jevgenerus wrote:
05 Sep 2018, 00:24
For compiling:
you will need to adjust for the path where you unpacked QScintilla2 source for example.
Jevgenerus wrote:
05 Sep 2018, 00:24
again, I think this step is needed only for those library you manually compile, such as QScintilla2. you will need to copy libqscintilla2....so to the same directory where the vrep executable is.
