ROSInterface question: ROS Node at another machine
Klaus
Post by Klaus »
Hello all,
According to this:
http://www.coppeliarobotics.com/helpFil ... Interf.htm
When we want to use ROS with Vrep, what happens is that once we start Vrep with ROSInterface support, it finds a roscore running in the network and creates a ROS Node that serves as communication point between VREP and the ROS network. Something like this:
Scenario 1
  • Machine 1
    • VREP
    • VREP's ros node
    • roscore
    • other ros nodes
    • ros master
Due to how computationally demanding VREP and other ros nodes (e.g. image processing, path planning) we are running VREP in a separate machine. Something like this:
Scenario 2
  • Machine 1
    • VREP
    • VREP's ros node
  • Machine 2
    • roscore
    • ros master
    • other ros nodes
However, we would like machine 1 not to require a ros installation to work. And focus only on running VREP. So the ideal case would be something like scenario 3:
Scenario 3
  • Machine 1
    • VREP
  • Machine 2
    • VREP's ros node
    • roscore
    • ros master
    • other ros nodes
In this case, everything related to ROS would be running in a separate machine.
Question; is this possible?
Regards,
Klaus
Re: ROSInterface question: ROS Node at another machine
The RosInterface plugin requires ROS.
Moreover, it is not possible to run V-REP's (RosInterface's) ROS node without V-REP.
