Setting object position in V-REP
trabias
Post by trabias »
Hi!
I have arrays of values calculated in MATLAB for the x, y, and z position and I'm trying to find the best way to send that information to V-REP. My initial idea is to use simSetObjectPosition within a for loop in a child script so that it runs through the all of the values and changes the position in real time. I'm not fluent in C programming, is there a good example that I can follow along?
Thanks!
Sarah
Re: Setting object position in V-REP
Hello Sarah,
if you are using Matlab, use the function simxSetObjectPosition:
vrep.simxSetObjectPosition(clientID,objectHandle,-1,objectPosition,vrep.simx_opmode_oneshot);
trabias
Post by trabias »
Thanks for the quick reply! I received this error and was wondering if you had any ideas what is the issue? I tried to adjusting the input for the position array different ways and I keep getting the same error.
No appropriate method, property, or field simxSetObjects for class remApi.
Error in startvrep (line 15)
[errorCode]=vrep.simxSetObjects(clientID,0,-1,[x(100) y(100) z(100)],vrep.simx_opmode_oneshot);
Error in quadrotor_sim (line 8)
Thanks!
Sarah
Oops, I made a typo, the function is not simxSetObjects, but simxSetObjectPosition.
trabias
Post by trabias »
Ohh ok! Thanks! I ran the program now and it gives no issues, but the quadricopter doesn't move.... is there something missing from my code (included below) or should I add something to the child script to read the information given?
Thanks!
Sarah
function startvrep(xyz)
x=xyz(:,1);
y=xyz(:,2);
z=xyz(:,3);
disp('Program started')
vrep=remApi('remoteApi','extApi.h');
clientID=vrep.simxStart('127.0.0.1',19999,true,true,5000,5);
if (clientID>-1)
    [errorCode]=vrep.simxStartSimulation(clientID,vrep.simx_opmode_oneshot_wait);
    [res,objs]=vrep.simxGetObjects(clientID,vrep.sim_handle_all,vrep.simx_opmode_oneshot_wait);
    [errorCode,handle]=vrep.simxGetObjectHandle(clientID,'Quadricopter',vrep.simx_opmode_oneshot)
    disp('Controlling the xyz position')
    for i=1:1601
        [errorCode]=vrep.simxSetObjectPosition(clientID,handle,-1,[x(i) y(i) z(i)],vrep.simx_opmode_oneshot);
    if (res==vrep.simx_error_noerror)
        fprintf('Number of objects in the scene: %d\n',length(objs));
        fprintf('Remote API function call returned with error code: %d\n',res);
    vrep.simxFinish(clientID);
    disp('Failed connecting to remote API server');
        vrep.delete();
disp('Program ended');
You have 3 problems in your code:
  • when retrieving the handle of the object, use a blocking mode operation, i.e. vrep.simx_opmode_oneshot_wait, otherwise you won't retrieve the handle. Make sure you have understood how the remote API operates.
  • you should control the position of Quadricopter_target, not Quadricopter!
  • when sending positions, put some wait commands, otherwise everything is sent and arrives more or less at the same time.
cpscps
Post by cpscps »
Hi Sarah!
I want to use a quadricopter in the same way and I have the same problems so I would like to know if you finally could make your project work.
Thanks in advance!
first you need to determine how you want to connect CoppeliaSim to Matlab. Then, there are several options to transmit data from one to the other.
