Joint Dynamics Properties on NAO Controller
Posted: 22 May 2019, 17:31
by VivianaMoya
Hi everyone,
I need some help in a controller I'm developing for a NAO Robot.
I calibrate the controllers in Joint Dynamics Properties, but I need to program it in sysCall_jointCallback and used this code:
http://www.coppeliarobotics.com/helpFil ... ctions.htm
But the controller does not work, maybe there is something else that I should calibrate or put in, because the current output remains saturated in a value but still increases the constants of the PID controller (Kp, Ki, Kd).
Thank you all for your help.
Re: Joint Dynamics Properties on NAO Controller
Posted: 27 May 2019, 05:43
what do you mean with "it does not work"? what is it intended to do, and what does it do?
The controller code from the user manual is a position controller. Try to use default values from the physics engine, and a default controller. From there, slowly modify one or the other until something doe not work anymore. Then you will know where the problem lies...
Posted: 11 Jun 2019, 18:13
by VivianaMoya
coppelia wrote: ↑27 May 2019, 05:43
I want to implement the position controller in the function sysCall_jointCallback (inData) since it is 10 times faster than a normal script.
Currently, I generate references from Matlab, sent them to vrep and use the Joint Dynamics Properties controller and the walk controller works very well. But when I want to implement the controller as explained here:
http://www.coppeliarobotics.com/helpFil ... ctions.htm, the outputs no longer follow the reference even if I put very high proportional currencies, and with what I read, it is supposed to work the same but the controller does not work in the jointCallback function.
I have found the error, and when I enabled the controller in Joint Dynamics Properties and also enabled the jointCallback function, I draw the position error and there is none, with the references you sent from matlab. But when I leave only the jointCallback enabled with the proposed PID controller and the constants used in the interface and it does not work I have a position error of 100%.
I really do not know why it does not work.
Posted: 14 Jun 2019, 13:08
Please try to make a minimalistic example that illustrates your problem. Best would be to have a very simple scene with a single joint. Debugging a complex robot such as the NAO robot is almost impossible if you do not break things down.
