Remote API (legacy) client sends command to wrong remote API host
Uli_v
Post by Uli_v »
In my small working example to reproduce the bug I have two remote API clients that communicate to 4 remote API servers. The clients connect to the simulation, restart (stop/start) the simulation, print something to two terminals and console of the simulator (via remote API calls). If I do that with two clients a few times, then it might happen that the message belonging to different terminals/hosts appear in the same or wrong terminal/host. I tested this with V-REP 3.5.0 and 3.6.1 rev3 (both have the issue).
Here is the working example to reproduce:
https://drive.google.com/open?id=1u6OW7 ... WpfVJgjSMD
How to reproduce:
Start 4 simulators, one in each terminal
 ./vrep.sh multiple_remote_api_host_clients.ttt  -gREMOTEAPISERVERSERVICE_19997_FALSE_FALSE
 ./vrep.sh multiple_remote_api_host_clients.ttt  -gREMOTEAPISERVERSERVICE_19998_FALSE_FALSE
 ./vrep.sh multiple_remote_api_host_clients.ttt  -gREMOTEAPISERVERSERVICE_19999_FALSE_FALSE
 ./vrep.sh multiple_remote_api_host_clients.ttt  -gREMOTEAPISERVERSERVICE_20000_FALSE_FALSE
Run this script with arguments "0 1" first:
python multiple_sims_debug.py 0 1
Observe outputs in the terminals (and simulation). It should print the right output to two different terminals.
Run this script with arguments "2 3":
python multiple_sims_debug.py 2 3
Run this script with arguments "0 1":
Observe outputs in the terminals (and simulation). You might have to repeat running "python multiple_sims_debug.py 0 1" and "python multiple_sims_debug.py 2 3" a few times until the issue happens.
ISSUE!
It is now printing to the single terminal (e.g. terminal started with port 19998, offset 1) and nothing to terminal 0 (started with port 19997, offset 0).
In same terminal it prints:
Print via API call: 	sim_port_offset 0?
Print via API call: 	sim_port_offset 1?
The first line is the issue (it should not print "sim_port_offset 0" in terminal started with port 19998, with sim_port_offset 1).
It also printing to the same V-REP console (GUI).
Re: Remote API (legacy) client sends command to wrong remote API host
before I dig deeper into this issue, can you make sure that you do not additionally try to open a remote API port via the file remoteApiConnections.txt ?
Uli_v
Post by Uli_v »
I though that these just specify the configuration of the servers (if started), but they actually start the servers too? I will comment them out and try again.
I got this in the remoteApiConnections.txt (for V-REP 3.6.1 rev3).
portIndex1_port             = 19997
portIndex1_debug            = false
portIndex1_syncSimTrigger   = false
And this in V-REP 3.5.0:
portIndex1_syncSimTrigger   = true
