[Crash] V-Rep doesn't like this Pipeline
RL_Niryo
Post by RL_Niryo »
During my model creation on V-REP, I met a issue couple of times, which lead to multiple crashes & work lost.
I recreate this pipeline on my coworker desktop, and it crashed as well.
This pipeline is kinda simple :
- create something like a Producer,Sink,...
- You want to research a keyword/variable, so you type Ctrl+F
- Your research is now finished, and you want to close search tab by using Echap.
- The script will close, and then, you cannot do anything during ~5 seconds, which is the last step before the crash
Issue happened on both last version of EDU & PRO
I hope you can reproduce this and find the problem
Have a good day :)
Re: [Crash] V-Rep doesn't like this Pipeline
Good catch!
Thanks, we'll look into this. As a workaround, try to close the search panel via the button.
RL_Niryo
Post by RL_Niryo »
Thank you ^^
Yep, I'm currently using this way, working well :)
Regards
