how to build a counter for the laser pointer when the laser pointer was triggered ?
jianye
Post by jianye »
hello,
i have built a safety light curtain and i want to build a counter to store the times that the laser pointer was triggered.
how can I realize this function ?
any advice ?
Jian
Re: how to build a counter for the laser pointer when the laser pointer was triggered ?
The simplest is to use a non-threaded child script for that. In the sensing section, read your proximity sensor with sim.readProximitySensor. Compare the detection value with the value read in previous simulation step. If the value goes from no detection to detection, then increment your counter.
jianye
Post by jianye »
hello,
how can I know the detection status of no detection and detection?
and can i read the value of the previous simulation step?
thank you in advance.
Jian
jianye wrote:
28 Nov 2019, 21:42
hello,
jianye wrote:
28 Nov 2019, 21:42
Before storing the result in a variable, that variable will contain the result of the previous simulation step.
E.g.:
function sysCall_sensing()
    result,d,p,h,n=sim.readProximitySensor(sensorHandle)
    if oldresult==0 and result==1 then
        -- do something
    oldresult=result
jianye
Post by jianye »
I understand, thank you so much.
