UI Toggle for enabling user parameters
bknight-i3drobotics
Post by bknight-i3drobotics »
Currently to enable/disable the user parameter tool for an object is done using the following function in the Lua command console:
sim.setUserParameter(objectHandle,'@enable','')
The feature request is to have this ability with a tick box in the object properties dialogue. Or some other UI way of setting this property.
Re: UI Toggle for enabling user parameters
shouldn't the parameter be set from the embedded child script? e.g.:
    sim.setUserParameter(sim.handle_self,'@enable','')
although this has the drawback that the icon will appear only after running the scene the first time, but for me works quite well.
Otherwise, if you want to see the icon right away, you can use a customization script to set that param, e.g. similarily during initialization.
But if a UI element must be added, I'd say it should be a menu item, similar to Add -> Child Script, e.g. Edit -> Script parameters... that would show the parameters window also when empty, whereas if some parameter is set the icon is normally visible.
