calling simROS2.advertiseService causes crashing
Blaise
Post by Blaise »
Hi everybody
When creating a ROS2 service in a non-threaded script:
service = simROS2.advertiseService(proxy_node..'/service', 'std_srvs/Empty', 'service_callback')
the simulator crashes with the following error message:
libsimExtROS2Interface.so: undefined symbol: _ZN22rosidl_typesupport_cpp31get_service_type_support_handleIN8std_srvs3srv5EmptyEEEPK29rosidl_service_type_support_tv
I am using CoppeliaSim Pro V4.0.0. (rev. 4) with ROS2 Eloquent Elusor on Ubuntu 18.04. The ROS2 plugin for the simulator loads properly since I've been able to communicate in publisher-subscriber manner with no issues - only services lead to crashing. The same problem occurs when calling simROS2.createService.
Any ideas how to fix it?
All the best,
Blaise
Blaise
Re: calling simROS2.advertiseService causes crashing
Post by Blaise »
The situation has been reproduced on other machines, hence the suspicion that it could be a bug rather than a setup issue.
Looks like a linker issue to me.
Can you reproduce with ROS2 Dashing Diademata?
