Error opening CoppeliaSim on Ubuntu 20.04 LTS
darn
Post by darn »
I get the following error when I open CoppeliaSim:
CoppeliaSim Edu V4.0.0. (rev. 4)
Could not find or correctly load the video compression library.
Try following:
>sudo apt-get install libavcodec-dev libavformat-dev libswscale-dev
if above fails, try first:
>sudo apt-get -f install
I have already installed the codecs suggested in the error but I still get the same message. Does anyone have the same problem?
Thank in advance!
lhcubillos
Re: Error opening CoppeliaSim on Ubuntu 20.04 LTS
Post by lhcubillos »
I have the same problem! Did you manage to solve it?
can you try with the new release (V4.1.0) that will be out within a few hours?
Corrie
Post by Corrie »
I have this problem, too, even using the new release, CoppeliaSim 4.1.0 with Ubuntu 20.04 LTS. In addition, the terminal reports errors loading other libraries: Image, ROSInterface, and BlueZero. Any idea why this is happening? Are other users also getting errors in terminal loading the above libraries on CoppeliaSim start-up?
I'm having trouble running a VRep sceneas well, and trying to determine if the missing libraries are the cause...
~C
Is your Ubuntu 20.04 a clean installation? What exactly is the output in the terminal when launching CoppeliaSim?
