Crash with not too much info why
rw1445
Post by rw1445 »
Hi
Coppeliasim keeps crashing but only intermittently and the only reason it gives is std::bad_alloc.
Full description from terminal:
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
./coppeliaSim.sh: line 33: 4985 Aborted (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
I believe it is something to do with a height field I am creating from a Python program by calling a Lua function.
https://drive.google.com/drive/folders/ ... sp=sharing
Above is a link to basically everything I am using:
18w 30t.ttm - is the robot model I have been using
terrain test ground mar20.ttt - the scene with the lua script in
createterrain1.py - program that creates the terrain
controlTerrain.py - program that controls the robot, start/stop scene and calls createterrain1.py
Other info - using latest coppeliasim on ubuntu 18 but the computer is reasonably basic. Processor: Intel® Core™ i5 CPU 650 @ 3.20GHz × 4 , Graphics: Intel® Ironlake Desktop
Been trying for about a week to try and figure out what might be causing this. Any help would be much appreciated. If there is any other info you need let me know.
Re: Crash with not too much info why
you are saying it crashes intermittently... that means you can't easily reproduce the crash, right? So it happens every x minutes, or y hours approximately?
If you could find out which Python call happens last, that would already be a beginning. Are you using the legacy remote API? Does it happen only with one physics engine or with all of them?
Also, you could try to enable printing debug info via [menu bar --> Help -->Debug ] and enable Debug internal function access, Debug C API access and Debug Lua API access. Things will run much much slower however...
rw1445
Post by rw1445 »
It can be reproduced but with a bit of time as I am looping the simulation run it happens within the first 1-15 min. It happens mid-run so when the robot it moving towards a target coordinate. I was using ODE with coppeliasim, downloaded old vrep and tried that with bullet 2.78 & ODE which did still created the crash. Currently trying it with Bullet and coppeliasim which so far hasn't crashed.
In the python script during the sim it only calls 4 function : Settargetvelocity, getposition, getorientation and getLastcmdtime.
The inputs to the function for the last three don't change and I printed to values of the target velocities which were always numbers so wouldn't be causing an error.
I did already run the Debug printing but couldn't make much sense of it, will upload that to the google drive folder.
The main thing is if I change the terrain to a bunch of steps instead (in my code t =2) it doesn't crash. So it seems to be some sort of interaction with the height field that I am creating.
Thanks for your help, it is much appreciated.
rw1445
Post by rw1445 »
Update: Well sticking with coppelia and changing the physics engine to bullet 2.78 might have fixed it. Its been running for about a hour now without crashing. I would still like to know what was going wrong if possible. The reason I was using ODE was it seems to be the only one that deals with a cylinder on its side in a sensible manner (try it, its great).
Rob
