_install TARGETS given no LIBRARY DESTINATION for shared library target simExtROS2Interface
Filipe Rocha
Post by Filipe Rocha »
Hi everyone.
I am trying to compile the ROS2 interface .so in ROS2 Dashing on Ubuntu 18.04. By just following the steps on the Github repo (https://github.com/CoppeliaRobotics/simExtROS2Interface) I get the following error:
> colcon build --symlink-install --cmake-args -DCMAKE_BUILD_TYPE=Release -DLIBPLUGIN_DIR=$COPPELIASIM_ROOT_DIR/programming/libPlugin
Starting >>> sim_ros2_interface
--- stderr: sim_ros2_interface
CMake Error at /opt/ros/dashing/share/ament_cmake_core/cmake/symlink_install/ament_cmake_symlink_install_targets.cmake:50 (_install):
  "simExtROS2Interface".
Call Stack (most recent call first):
  /opt/ros/dashing/share/ament_cmake_core/cmake/symlink_install/install.cmake:37 (ament_cmake_symlink_install_targets)
  CMakeLists.txt:128 (install)
Failed   <<< sim_ros2_interface	[ Exited with code 1 ]
Summary: 0 packages finished [1.50s]
  1 package failed: sim_ros2_interface
  1 package had stderr output: sim_ros2_interface
I think I made a workaround by adding
set(LIBPLUGIN_DIR ${COPPELIASIM_ROOT_DIR}/programming/libPlugin)
to the <ros2_ws>/src/sim_ros2_interface/CMakeLists.txt . Well, I think because the error has changed after that hahaha:
CMake Error at CMakeLists.txt:56 (find_package):
  By not providing "FindCoppeliaSim.cmake" in CMAKE_MODULE_PATH this project
  has asked CMake to find a package configuration file provided by
  "CoppeliaSim", but CMake did not find one.
  Could not find a package configuration file provided by "CoppeliaSim"
  (requested version 4.0.0.0) with any of the following names:
    CoppeliaSimConfig.cmake
    coppeliasim-config.cmake
  Add the installation prefix of "CoppeliaSim" to CMAKE_PREFIX_PATH or set
  "CoppeliaSim_DIR" to a directory containing one of the above files.  If
  "CoppeliaSim" provides a separate development package or SDK, be sure it
  has been installed.
Summary: 0 packages finished [0.69s]
After that, I have added the redundant
set(CoppeliaSim_DIR ${COPPELIASIM_ROOT_DIR})
to CMakeLists.txt... nothing have changed. I have also searched for the CoppeliaSimConfig.cmake and coppeliasim-config.cmake files on my computer, but did not found them.
I am not an expert on CMake, so this hard time has been a good time to study some concepts. hahaha
I kindly appreciate any suggestions on how to manage that. :)
Best regards.
Re: Failing on building ROS2 interface on Ubuntu 18.04
You don't need to change CMakeLists.txt or other files.
Make sure the value of $COPPELIASIM_ROOT_DIR is correct.
Filipe Rocha
Thank you for the quick response.
I see there is no need for modifying CMakeLists. I am probably doing something wrong on my own.
Starting from the beginning for a re-check purpose, I have just downloaded CoppeliaSim 4.0.0. (rev4) and cloned to `<ros2_ws>/src` the ROS2 interface using
git clone --recursive https://github.com/CoppeliaRobotics/simExtROS2Interface.git sim_ros2_interface
(Additionally, the github repo indicates a "libPlugin's README" link, which is broken.)
The $COPPELIASIM_ROOT_DIR var is set to
> echo $COPPELIASIM_ROOT_DIR
/home/filipe/bin/coppelia
which is correctly my CoppeliaSim folder.
Now, when I run the compilation command suggested on the github repo i get:
  CMakeLists.txt:124 (install)
Summary: 0 packages finished [1.45s]
Changing the compilation command to the one suggested in the official CoppeliaSim website:
Summary: 0 packages finished [1.44s]
I understand the additional parameters on the second compilation command is precisely for setting the lib folder. Still, my colcon presents a related error.
Thank you in advance for any tips on how to solve this. :)
Best regards.
Oh. I think that error is coming from here:
#cmake
# sim_ros2_interface/CMakeLists.txt
install(
    TARGETS simExtROS2Interface
    EXPORT export_${PROJECT_NAME}
    ARCHIVE DESTINATION lib
    LIBRARY DESTINATION ${COPPELIASIM_PLUGINS_DIR}
    RUNTIME DESTINATION bin
You need to pull the latest version of libPlugin to have the ${COPPELIASIM_PLUGINS_DIR} variable properly set.
This issue will be fixed once the next release of CoppeliaSim will include also the latest version of libPlugin.
However it is a good habit to have all the CoppeliaSim libraries (include, common, libPlugin, simMath, etc...) to the latest version when building plugins from git.
whajoost
Re: _install TARGETS given no LIBRARY DESTINATION for shared library target simExtROS2Interface
Post by whajoost »
Hi, I have a question about the libPlugin.
Whenever I try to compile the plugin i get the error that the CoppeliaSimConfig.cmake cannot be found. I think it has to do with the fact that the set(LIBPLUGIN_DIR $ENV{COPPELIASIM_ROOT_DIR}/programming/libPlugin) described in line 43 of the cMakeLists.txt cannot be found. I tried to look for the folder but there is no /programming directory in my coppeliasim folder. Can you please help me? I have CoppeliaSim v4.1.0 on ubuntu 20.04 and want to change the plugin since i need to add extra message types to the meta/interfaces.txt file.
