How to use half a primitive shape
kp901
Post by kp901 »
Hi
Is there any good way to create half a sphere and still keep it a primitive shape? I can even deal with deleting the triangles in the shape edit mode bit by bit by bit, but that does end up making the shape not primitive, and I'm having issues using non-primitive shapes as sort of "wheels" (or maybe there is a nice way to deal with that besides the shapes going wild after getting connected via joints?)
Re: How to use half a primitive shape
Why would you need that?
If you explain your problem, instead of telling how you are trying to solve it, a better solution can be found.
you can't have such a primitive shape. But you can use modify a sphere to a half-sphere, then extract the convex hull from it. Then you'll have a convex shape, that will perform much better than a random shape when using physics engines in your simulation.
