How to use SICK_S300 to detect object ?
jianye
Post by jianye »
hello,
i use two SICK_S300 sensor to detect person in the scene but result of detection turned out always zero.
scene: https://ibb.co/9HbZPQ5
 visionSensor1Handle=sim.getObjectHandle("SICK_S300_sensor1_1")
    visionSensor2Handle=sim.getObjectHandle("SICK_S300_sensor2_1")
    visionSensor3Handle=sim.getObjectHandle("SICK_S300_sensor1_2")
    visionSensor4Handle=sim.getObjectHandle("SICK_S300_sensor2_2")
    BillHandle=sim.getObjectHandle('Bill_base')
    rst,a1,a2,a3 = sim.checkVisionSensor(visionSensor1Handle,leftLeg)
    print(rst)
I want to know how can man use SICK_S300 sensor to detect object?
bests,
Jian
Re: How to use SICK_S300 to detect object ?
check the script attached to your sick 300 model: it contains everything you need to know. The sensor is composed by two vision sensors. Those are read in the sensing section (sim.readVisionSensor) and the data is computed for absolute coordinates. Then those points are used to draw the red lines you see when you run the simulation.
