Shortcuts
minisch
Re: Shortcuts
Post by minisch »
Yeah but it doesn't work.
With ctrl+SPACE I can start and stop the simulation as before. But with ctrl+B nothing happens.
Re: Shortcuts
That is strange.. I cannot explain why this doesn't work for you. If the focus is on the main window, it should work. Can you try with a different scene, that has a single view (default) with a single robot?
minisch
Re: Shortcuts
Post by minisch »
I just tried and nothing happens with ctrl-B.
EDIT: Just to let you know. If I go in about VREP I have the 3.2.0 Version.
Re: Shortcuts
Can you try to add a customization script to a object in the scene, and to put following code in it:
if (sim_call_type==sim_customizationscriptcall_nonsimulation) then
	local a,b=simGetSimulatorMessage()
	if a==sim_message_keypress then
		print(b[1],b[2])
What does it print if you try <ctrl>+b? What does it print if you try <ctrl>+m?
You could also add simCameraFitToView(0) in the above code, and have your customization script take care of the camera adjustment. The only problem, it will only adjust for the view you specify, not the view that is in focus..
Re: Shortcuts
Oh.. it should say 3.2.1, so you do not have the BETA version it seems
minisch
Re: Shortcuts
Post by minisch »
I thought about it and I wrote it in my previous message because I thought about something like that.
I will try the beta version and come back to you.
Thanks for the effort.
minisch
Re: Shortcuts
Post by minisch »
I updated V-REP to 3.2.1 and it is working.
Thanks.
