Creating pipeline in Coppeliasim
Posted: 06 Oct 2020, 11:14
by keyurshukla
I want to create pipeline environment with bends in Coppeliasim. How to create that? I want to run robot inside Pipeline
Re: Creating pipeline in Coppeliasim
Posted: 09 Oct 2020, 07:11
if your pipe needs to be dynamically enabled, and your robot run inside of it, then it is not such a good idea to use the pipe's mesh, since it will result in instabilities and be very slow. Better is to approximate the pipe with primitive shapes, e.g. cuboids. You can do this manually (not recommended, since tiresome work), or you can programmatically generate the pipe using (among others) sim.createPureShape and sim.groupShapes.
In this example scene a pipe mesh is being automatically followed, and a primitive shape model created from it.
Posted: 09 Aug 2022, 09:58
by RobertPastor
the link to the example scene is no longer available. Could you please upload it again?
Posted: 09 Aug 2022, 10:58
you can find the same example in your CoppeliaSim scenes folder, at scenes/otherScenes/pureTubeExtraction.ttt
