GUI rendering on High res displays
Juancho
Re: GUI rendering on High res displays
Post by Juancho »
coppelia wrote: 15 Nov 2022, 13:11 Hello Juan,
Since CoppeliaSim V4.4, the usrset.txt file is not located in <installDir>/system/ andymore. Type following into the statusbar, to get an idea where the settings file is located:
> sim.getStringParam(sim.stringparam_usersettingsdir)
Thank you!
I found the file using your suggestion. In my case is:
>"C:\\Users\\my-user\\AppData\\Roaming/CoppeliaSim"
